Old 10-16-2011, 07:39 PM   #1
vancouver , British Columbia
Burner and Blower Won't Start For Furnace
Hey guys,
my dad was trying to fix the furnace because its not working and won't produce heat. I looked up briefly on the net to find a solution to this and found one method on here by a fella named 'lewster'. He suggested that the thing you should check up first is the t-stat, where you open it up and connect two wires and wait a few seconds to see if the furnace starts up again. My dad tried this and nothing happened.
What could be the problem? Any suggestions and helpful things we could do would be appreciated. thanks.
I'll provide some info if need be.
heyhello is offline   Reply With Quote
Old 10-16-2011, 08:20 PM   #2
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
Please Tell Us More
Like what is the year and make of the Airstream?
Is it Suburban furnace?
What is the ignition method?
Have you checked the sail switch?
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 10-31-2011, 07:31 AM   #3
saburkha's Avatar
1976 Argosy 28
Tuscola , Texas
i'm having similar issues with my 1976 suburban furnace. I can get the pilot to light and stay on, but nothing happens when i adjust the thermostat. No blower, no burner. Not sure if I should be looking at a thermostat problem or elsewhere. That may be where i start first before attempting to get into the guts of the furnace. Any help would be appreciated.
saburkha is offline   Reply With Quote
Old 10-31-2011, 08:51 AM   #4
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
I agree with Ken: We need more info about what heater you're talking about and the exact symptoms.
In general, I've found quite a few problems with sail switches. In our model, when the sail switch fails, the fan will start up, but there's no propane flow, and the ignitor will not work. Remove the sail switch, clean it up (or replace it), and the heater works fine.
Lynn
WBCCI 21043
Old 05-27-2015, 03:43 PM   #5
1973 29' Ambassador
Seattle , Washington
Hi, I've read several of the threads on this issue and would like advice on the order I should check things.
I have a 1973 Ambassador with the suburban furnace (pilot light, not circuit board).
Furnace worked fine last season, this season, went to use it and experienced the following.
1. turned on gas valve under sink that supplies furnace
2. open view window an lit pilot. pilot stays burning
3. close view windows and inspection cover that you have to open to see the light
all of the above is exactly as I've done it every year (this is our 3rd year with the trailer).
4. crank up thermostat... NOTHING happens
5. recheck that pilot is still going, yes it is.
I have jumpered the thermostat, thinking that maybe that would do it, but that didn't work.
I have checked the main fuse in the converter fuse block for the furnace and it's fine.
What can I check next before calling a mobile rv repair guy out to fix it. (it's in my driveway now, so easy for me to try a couple of easy things.
Any help would be appreciated. thanks!
dcheshire is offline   Reply With Quote
Old 05-27-2015, 04:39 PM   #6
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
The blower should immediately kick on when the thermostat calls for heat. Are you plugged into shore power? Batteries fully charged? Inadequate voltage to the unit will cause the blower not to function properly. Ou must have proper blower speed to activate the sail switch which activates the gas valve. Im guessing low voltage, bad connection to furnace (check with meter at furnace), or blower motor kicked the bucket
mayco is offline   Reply With Quote
Old 05-27-2015, 07:17 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Folks.. Check age of thread. It is pretty old...
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-27-2015, 07:39 PM   #8
mayco's Avatar
I saw that, looked to me like they were searching through old threads to find something that related to their situation. Dunno.
Old 05-27-2015, 07:40 PM   #9
mayco's Avatar
Their post was from 4:43 pm today
Old 05-27-2015, 07:43 PM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
My mistake, Mayco... please forgive.
Channing
WBCCI# 30676
Old 05-27-2015, 07:56 PM   #11
mayco's Avatar
No biggie
Old 05-28-2015, 10:11 AM   #12
1973 29' Ambassador
Hi folks. Sorry for resurrecting an old thread. My hope was to not go over the things already covered in the previous thread. So I've got a pilot going, and I've "short circuited" the thermostat and I've checked the one fuse I know about (unless there are secret inline fuses somewhere).
So now it sounds like
1. check voltage at thermostat?
2. check voltage somewhere in the furnace?
Old 05-28-2015, 10:13 AM   #13
1973 29' Ambassador
Hi, to answer this. This happened when on shore power (13.X volts in the system from PD9245 converter) and when just on a fully charged batter (all lights/etc are bright, no reason to think voltage is low).
Old 05-31-2015, 04:03 PM   #14
1973 29' Ambassador
Checking further, there is no voltage at the thermostat. Is there an inline fuse between main fuse box and the furnace?
