Can anyone recommend a size for a/c on a 22' A/S in Texas? I have a '59 Flying Cloud and am considering the 11,000 BTU Penguin (recommended size by the company I intend on hiring to install). Would the 13,500 be oversized or too heavy? ..I understand reinforcement will be needed in the roof. Any specifics on how to do that would be appreciated.
John, I would up size to the 13,500 BTU unit if I were you. It's no fun camping in the Texas heat if your A/C won't keep up. I have a 31' landyacht that originally had a 13,500 BTU. I installed a 15,000BTU and it cools wonderfully. I installed it myself and it took a full day to remove the old and install new. Camping World up in New Braunfels wouldn't commit to a install price, since AS are a bit harder to work on .
I tend to agree with you about getting the 13,500 BTU Penguin instead of the 11,000 BTU for my 22' Flying Cloud. I checked the net and found the weight of the two to be the same (104lbs).
I would like to hear a good argument for the 11,000 BTU for a 22' if anyone has one. I am just trying to play 'devils advocate' ...
Originally posted by jlawrence II would like to hear a good argument for the 11,000 BTU for a 22' if anyone has one. I am just trying to play 'devils advocate' ...
John.
The only argument might be the fact that at night time, the 11K compressor will run a little longer before reaching set point, thusly removing more humidity from the air. If I were in your shoes I'd go with the 13.5K unit. You need that extra capacity in the hot Tx. sun.
Jack
Jack Canavera
STL Mo. AIR #56
'04 Classic 30' S.O.,'03 GMC Savana 2500,'08 Vespa GTS 250
Keep in mind that here in Texas; we have primarily 'two kinds of heat.' Dry & wet. What part of The Lone Star State do you plan on doing most of your travels? I live near the Coast - lots of humidity. The larger unit will cool your AS faster, but along the coast, it won't have time to remove sufficient amounts of humidity - then you have a mildew/mold [M&M] problem.
One of the primary reasons people are having all of the M&M problems in their homes is the high efficiency A/C units sold today - they cool quickly, but don't have time to remove the moisture, which is a breeding ground for the M&M.
I wonder if anyone uses a dehumidifier in their trailers when in storage?
