Old 04-17-2016, 09:08 PM   #1
box with external vent for catalytic heater?
I have been hesitant to put a catalytic heater (wave 6, e.g.) in my Avion (25' 1985) due to concerns about breathing the oxidation products. Has anyone tried to put a 'duct free' radiant heater in a box with a glass front, or under a hood? Either approach would involve providing an external vent and likely an external air supply. I see you can get a 24" x 18" sheet of high temp tolerant glass; some bent aluminum sheet metal could be used. It would not have to be completely air tight, just able to capture and vent most of the combustion products. I welcome your thoughts, ideas, and experience. I also understand that this may trigger some strongly held beliefs, which may not all be in agreement, so I am grateful for the gentle and reasonable tone that is part of any discussion on this site.
dower.bill is offline   Reply With Quote
Old 04-17-2016, 11:23 PM   #2
SuperTrouper's Avatar
2008 27' International CCD FB
Petaluma , California
How about one of these?
http://www.walmart.com/ip/30194018?w...052057&veh=sem
SuperTrouper is offline   Reply With Quote
Old 04-18-2016, 06:14 AM   #3
Images: 59
I would be less concerned about inhaling combustion products (like carbon monoxide) and more concerned about oxygen depletion.
I don't know if that would change your box design or not.
Old 04-18-2016, 06:14 AM   #4
1994 30' Excella
Mississauga , Ontario
Check out PlatCat heater online.
Al
Al and Jean
TAC ON-3
Old 04-18-2016, 11:07 AM   #5
1996 25' Excella
Tillsonburg , Ontario
If you just want to take off the chill then I wouldn't be worrying about some CO2, water vapor and a bit of CO. I set the bedroom fan to run 'in' and open the living area vent about 1/2. That is more than enough to meet the standard for 22 sq in for passive vent area. I would never go to sleep with the catalytic running, but I routinely use it while sitting watching TV or making meals on a cool day. Personally I can't stand the noise of the furnace and it has such a large dead band in the thermostat that it is useless for anything but heating the trailer first thing in the morning
JCW
JCWDCW is offline   Reply With Quote
Old 04-18-2016, 11:44 AM   #6
1966 20' Globetrotter
2008 23' International
Cedar Falls , Iowa
Send a message via AIM to hahnstead
I have catalytic heaters in both of my trailers. Never worry about letting them run all night while I'm sleeping. I sometimes forget to crack a window. Just about any trailer is drafty enough that one doesn't necessarily need to open a vent, but opening the bathroom vent is a good idea, I suppose.
Hahnstead Airstream Park
hahnstead is offline   Reply With Quote
Old 04-18-2016, 01:20 PM   #7
HowieE's Avatar
Princeton , New Jersey
Images: 12
In the history of Airstreaming there has to have been thousands of Cat heater used. Mine for close to 20 years.While I do not leave it on while sleeping I have never heard of a problem from those that do.
Enclosing and venting this type of heater has got to reduce is effectiveness by more than 50%. These heater have a convective and radiant component. The glass would slash the radiant and the vent would exhaust most of the convective heat.
2004 Excursion 4x4
Old 04-18-2016, 03:46 PM   #8
kdickinson's Avatar
1969 23' Safari
Palmer Lake , Colorado
If you use the trailer at lower altitudes you can check out the marine LP heaters that boat owners install for overnight trips - but apparently don't work well above about 1500-2000' above sea level. They don't require electricity to run and from what I understand they do a really good job as a back up heat source when you are not plugged in. Dickinson (no relation) makes some models that look nice and I heard about them on the forum from people that are installing them in new Airstreams. They do require external venting and of course a source of fuel. We learned the hard way that, if you camp in the cold, you really do need an alternate heat source when camping even if you think you have electric. Having shore power may not always be the case. Power goes out at trailer parks too. And other things can happen like the time our inverter went out on us on a cold night (low teens F) in New Mexico and the furnace fan ran the battery down within 30 minutes. We now carry a Camco catalytic heater as a back up. We have a quick connect off the furnace to supply LP and the extension LP hose is long enough to place the heater most anywhere in the trailer depending on where we are while using it.
kdickinson is offline   Reply With Quote
Old 04-18-2016, 04:32 PM   #9
1973 31' Sovereign
Middletown , California
How about buying one of the newer ones that come with a built in power exhaust and can be used with a thermostat? They use little current and they were supposed to re-start production on these units. I don't think you could go wrong with one of those Dickerson fireplaces either. I tried an unvented catalytic heater and loved the way it heated but I'm sure the amount of moisture it adds to the air would ruin an Airstream over time from the moisture condensing inside the walls. I never could decide where I was OK with putting a hole for a vent so I ended up just resigning myself to situations where I had the power to use electric heaters. I'm sure a good powerless venting system could be fabricated for a catalytic heater and would be worth the hassle if you wanted to do it, but I don't think a box enclosing the whole heater would work. You would be better off with a fireplace type. I thought of fabricating a hood with a 2" chimney that mounted on my catalytic heater and exited out the roof thinking that would make a self powered vent but it would probably need a drain setup for condensation at least until the chimney warmed up. Never did that because I like to keep the bedroom above 45 degrees while I sleep so I had put an electric outlet controlled by a thermastat in the bedroom before I even had the catalytic heater. Quiet heat is a good thing!
ijustlee is offline   Reply With Quote
Old 02-14-2018, 09:34 PM   #10
Got the catalytic heaters in my Avion, with ducted exhaust
So I pulled the forced air furnace out of my 25' 1986 Avion with center bath, because I almost always boondock, and that furnace used too much battery.
I put a 'wave 3' high on the wall in the bathroom, near the ceiling vent. If I want a shower on a cold day, I open the vent, and turn on the Wave 3. The exhaust gasses go out along with a lot of moist air. The heater is enough to keep that little room nice and warm.
Photo ##433
For the living area, I put a hole in the wall where "the space behind" is where the burner for the fridge is. That is of course vented and well shielded from wind. Then I mounted a copper pipe (1 1/4") to duct the exhaust gasses out to that space.
I mounted a Wave 6 (on a slight angle to face the center of the room) on that wall. I folded some aluminum roofing flashing into a hood that captures the exhaust gasses, and holds them while the cool just a bit, then allows them to exit the cabin into the duct, and go behind the fridge.
I hope this series of photos provides enough to see what I did. It keeps the trailer pretty warm on cold days, and I have the CO detector to be sure I know if something is not keeping me safe.
Old 02-15-2018, 08:28 AM   #11
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
The pics did not post here
Matt
rugjenkins is offline   Reply With Quote
Old 02-16-2018, 03:02 PM   #12
views of adding DIY ducted Catalytic heater and vent
ID:	304345   Click image for larger version
ID:	304347   Click image for larger version
Old 02-16-2018, 03:05 PM   #13
second set of photos of Cat heater with DIY duct
ID:	304349   Click image for larger version
ID:	304351   Click image for larger version
Old 02-16-2018, 03:09 PM   #14
photos of ducted Cat heater set 3
photo inside heater cabinet, showing manifold for propane
Photo of upper wall in Bathroom, with ceiling exhaust fan, and wave 3 cat heater
ID:	304353   Click image for larger version
Exterior Catalytic heater Vent cover Squeakee Exterior Storage Compartments & Access Doors 1 10-28-2014 01:49 PM
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box betsy Airstream Classifieds 0 09-19-2014 11:01 AM
External Battery box by Torklift Rofkrynn Batteries, Univolts, Converters & Inverters 4 08-01-2014 10:12 AM
External battery box Loeber Batteries, Univolts, Converters & Inverters 7 08-16-2012 04:16 PM
Olympian Catalytic Heater davidz71 Furnaces, Heaters, Fireplaces & Air Conditioning 0 03-26-2002 10:47 AM
