Old 09-18-2008, 03:15 PM   #1
FT RVing
lebolewis's Avatar
1976 31' Sovereign
Always searching for a place w/low Humidity , FT RVing, N & S, E & W, & in between
Bowen B10G water heater drain plug
I need a drain plug for my water heater....mine is leaking. Can anyone point me in the right direction? Thanks Bill Lewis
When you get a chance to "Dance" or "sit this one out".......I hope you DANCE!
lebolewis is offline   Reply With Quote
Old 09-18-2008, 10:45 PM   #2
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I still have my old '65-'66 Bowen 6 gal. Think the plug will fit yours? I will check to see if it is useable tomorrow if you want it.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 09-19-2008, 07:09 AM   #3
FT RVing
lebolewis's Avatar
1976 31' Sovereign
Drain plug
Thanks Neil. If its brass and still in good condition, then I will take it. I will remove mine today and measure the diameter and let you know. Assuming it will fit is likely OK, but a measurement of the diameter will help. Thanks again, Bill Lewis
Old 09-20-2008, 11:49 AM   #4
FreshAir's Avatar
1966 24' Tradewind
Sorry, Bill. My drain 'plug' was not with the old tank. It isn't/wasn't a plug but it was a 3/4" cap. The drain pipe on the tank is a male thread. I rummaged around my box of brass fittings for it but could not see it. It is probably enjoying a new use on one of my other many projects. However, I tried a brass 3/4" fitting for size and it screwed on easily. The cap or plug that you need should be available at any good hardware store.
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Fresh water drain plug sticks skipj Fresh Water Systems 16 11-06-2009 06:43 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Needed, drain plug for hot water tank! wacnstac Fresh Water Systems 8 10-16-2007 08:22 PM
Bowen water heater 76'Sovereign Water Heaters, Filters & Pumps 3 08-30-2006 06:29 PM
