Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 03-04-2007, 02:05 PM   #1
Dan S
Dan S's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
Normandy Park , Washington
Boondock heating..how to?
In my quest for a AS or Argosy, I see many have forced air heating. If I'm without power, which I mostly do, how do I safely heat?
I know there are propane furnaces, but don't they need to be vented, and how/where would I install without it looking totally out of place?
Dan
Dan S is offline   Reply With Quote
Old 03-04-2007, 02:09 PM   #2
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
RVs are mostly self contained. If all the mechanicals are there the furnace will run off LP and 12v. I do this all the time and keep toasty warm when it's cold out when boondocking. One word of caution is that the larger furnaces will draw a lot of 12v, and depending on how often you do it or the size of the furnace, you may opt for a second battery, small generator, solar, etc, particularly if you'll be boondocking for more than 3-4 days and the furnace will run freq.
Old 03-04-2007, 02:20 PM   #3
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Search on 'catalytic' and follow any threads that seem to be related to heating.
Old 03-04-2007, 04:09 PM   #4
silverback
silverback's Avatar
Profile:  2006 28' Safari SE
Phoenix , Arizona
If you're replenishing your battery charge with solar or a generator worry more about propane supply. It also helps to have excellent batteries.
-KL
4CU Charter Member
2004 Silverado 2500 HD D/A
Honda EU2000i
Hensley Arrow
KE7DUI
silverback is offline   Reply With Quote
Old 03-04-2007, 07:10 PM   #5
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Dan
Dan, also check out Welcome to RV Solar Electric! since they sell and discuss the Olympian Wave 3 and 6 catalytic heaters. I installed a Wave 6 in my '77 Excella 500 31' and it did an excellent job. These heaters are ventless but you still need to crack a vent and window to provide some oxygen.
The other option, already mentioned, is a small Honda generator (EU1000 or EU2000) to keep the battery or batteries charged up. I currently use a Yamaha EF3000iSEB to run the AC if needed and to keep the battery charged up if using the furnace in my '86 Sovereign 25'. A 100 watt solar panel system will be added in April along with two 6 volt batteries on the tongue. I have also budgeted another 100 watt panel for April '08 if needed.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 03-04-2007, 07:16 PM   #6
davidz71
davidz71's Avatar
I forgot to mention that several of my hunting buddies have the Buddy heater and have used them successfully for the last several seasons. On really cold nights when they are turned up, they would have to change out the 16 oz tank. One went with a hose to a 20 lb. tank outside the camper and the other bought the newer Big Buddy. They are bulkier than the Olympian Wave 6 but more portable unless you buy the optional feet and hose setup for the Wave 6.
Craig
AIR #0078
3.73 rear end
Old 03-04-2007, 07:55 PM   #7
Smokin Camel
Profile:  1972 25' Tradewind
Madison , Wisconsin
Look at Examples
Dan
Go to a dealer and/or a rally. Look at the installations in the trailers. That should give you some ideas. If you buy a used trailer and the furnace is not serviceable look to see where the old one was and if a new one can be installed ther. The vent holes should already be in the side of the trailer.
Also look into the Dickenson Marine furnaces, they sort of double up as a fireplace. A bit pricey but it is in the eye (and the wallet) of thebeholder/buyer!
Having replaced a furnace, it was not all that bad. The worst of if for me was crafting out a base structure as the new furnace was much smaller than what it replaced. Read up on some of the furnace threads, maintenance is not that hard. Keep the wasp nests out of the vents and that is half the battle.
Smokin Camel is offline   Reply With Quote
transmission heating aeriqua Towing, Tow Vehicles & Hitches 15 08-03-2006 01:28 AM
A/C, Ventilation, and Heating Choices air19 Furnaces, Heaters, Fireplaces & Air Conditioning 6 12-11-2005 10:31 AM
Northern Alabama; Boondock or Campground? 73ANDY Off Topic Forum 4 05-04-2003 03:24 PM
Mister Heater/cheap heating options? Dave Cole Furnaces, Heaters, Fireplaces & Air Conditioning 5 12-14-2002 03:03 PM
Refrig. Heating Up rroessler Refrigerators 15 08-07-2002 06:46 PM
test
