Old 05-05-2016, 08:56 AM   #1
2015 16' Sport
Republic , Missouri
bird nests in air conditioner
I keep getting birds building nests in my air conditioner. Does anyone know of a cover of some type to keep birds out. I've got a 16' Bambi, 2015 with a Dominico (SP?) air conditioner. Looks like there's a opening on the side of the unit that's about 4x12 that's totally exposed where they are entering.
Kingpadog is offline   Reply With Quote
Old 05-05-2016, 09:12 AM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
If there is a 4x12 opening large enough for a bird to get into, the shroud (the AC's plastic cover) has been damaged.
It is easily replaced. Only 4 screws hold it on.
Google "Dometic shroud"
Old 05-05-2016, 09:18 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Screen wire over the opening. It sounds like you might already be missing a screen or filter of some sort. Can you post a picture of what you are talking about?
MICHAEL
Old 05-17-2016, 02:11 PM   #4
2015 16' Sport
Republic , Missouri
Got the bird problem figured out. There are four openings on the bottom of the shroud large enough for a bird to get into. We took the shroud off, attached screen to the inside of the shroud and put it back on. Problem solved. No broken or missing pieces.
I had enough bird nest material in the air conditioner to fill a 5 gallon bucket.
preventing wasp nests underneath Skooter Off Topic Forum 7 02-20-2014 07:32 PM
Mother of all Rat Nests Lumatic General Interior Topics 10 03-25-2007 07:59 AM
air conditioner air flow problem strawberryjo Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-05-2006 10:43 AM
Need a bird Tin Hut Off Topic Forum 10 07-17-2004 08:45 AM
Bird Droppings!!@#^* Navigator Cleaning, Stripping & Polishing 2 01-27-2004 11:13 AM
