05-13-2009, 08:13 PM
1965 24' Tradewind
Warner
, New Hampshire
Best Replacement for Furnace,Water Heater, and Range
Hello Everyone. I own and in the process of restoring my 1965 Trade wind Twin 24'.
I looking to replace my original International MGF 1525 Model furnace. Does anyone have any information about what furnace could be used as a direct replacement. I would like to use the same duct system if possible.
I'm would also like to replace my original Bowen water heater. I've read forums that recommend using the suburban and one other that I can't remember right now. I would like to know what others have used and there experiances.
Also The gas range has seen better days. Any information here would also be great.
Part of Me wants to try and see if they even work. But another part tells me to just replace the 44 year old units.
Thank You
Brian
05-13-2009, 09:48 PM
1967 26' Overlander
Winston Salem
, North Carolina
Hi.
Suburban and Hydro-flame are popular furnaces,
Water heaters are made by either Atwood or Suburban.
Stoves- there are more than one manufacturer, check out Camping World.
Atwood, Magic Chef, Suburban, and Wedgwood.
Hope this helps....
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
05-13-2009, 10:07 PM
1972 25' Tradewind
North Vancouver
, British Columbia
Bowen is now Atwood. The switch is fairly straightforward, just replace your present unit by one of the same size (6 or 10 gallon). They are available with a variety of options, like gas/electric heat, pilot ignition or electric ignition, etc.
North Vancouver, BC
05-13-2009, 10:54 PM
Corona
Thank You
Brian
Brian.
You should not use the International furnace as they fall apart internally, as well as the gas control valve leaks, both contributing to an internal explosion within the furnace. There was several modifications to those furnaces when new. But, none of them removed that furnace from the "junker" category that it so enjoyed, because of it's many faults and failures.
05-13-2009, 11:02 PM
Greeeneville
, Tennessee
Be sure to check out Palomino Parts. They are a division of Forest River (trailer manufacturer) and if you know what you want, they can save you a lot of money. The shipping is reasonable too.
Kevin with Baity the Lab/Pointer //------AIR # 7303------\\ WBCCI 17109 visit my restoration blog at:
05-14-2009, 05:59 AM
2008 16' Safari
Destrehan
, Louisiana
You really will not have much trouble replacing the componants in the trailer. I had an old 72 Safari and now have an 08 Safari. I was right at home in the new trailer. All of the componants are virtually the same as they were 35 years ago! The biggest change is the electronics. All the new stuff has ignitors so you don't need to run around lighting things when you set up camp.
If you size things right, most new parts will slip right in or only need very small mods to make them work.
05-18-2009, 05:47 PM
1965 24' Tradewind
Warner
, New Hampshire
I want to say thank you to everyone who responded to my question. I will be getting my new units real soon. The body will be separated from the frame this week then I can start putting things back together.
Brian
