Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 11-11-2007, 09:45 PM   #1
Grand Master's Avatar
1963 24' Tradewind
Anderson / Sun City , Indiana / Arizona
Best replacement for '63 Trade Wind International furnace
My 1963 Trade Wind has the original International furnace, and although it "looks" to be in good shape I have been advised to replace it.
What is the best and easiest replacement furnace to buy?
Can I keep the exterior furnace shroud from the International furnace? If not, what is the best way to replace without making the exterior too modified?
Mike Brumback
Anderson, IN
Grand Master is offline   Reply With Quote
Old 11-12-2007, 01:57 PM   #2
Aluminum Addict
Gastonia , North Carolina
The Suburban line of NT furnaces should be a good choice. The large opening on the exterior will have to be patched, but will not be too noticable. Most vintage AS trailers have had a modification or two. If a mod doesn't show, it may have had a panel replacement to hide the retro fit. The interior ductwork may have to be modified as well. I had a local sheet metal shop adapt the ductwork when I replaced the furnace in my '65 Safari.
Welcome to the FORUMS
---AIR # 17817---
DJ
Heirstreamer is offline   Reply With Quote
Old 11-12-2007, 02:28 PM   #3
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
A Wave catalitic heater is probably your best bet. Simple mount on wall, gas hook-up.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
'59 Trade Wind flyfshr 1959-69 Tradewind 196 03-10-2013 09:42 PM
Which replacement furnace for '72 Trade Wind? AronS Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-01-2007 02:18 AM
Need help on trade wind mercury7 1959-69 Tradewind 57 10-27-2006 06:38 PM
'61 Trade Wind DiMi Member Introductions 7 08-01-2006 03:00 PM
Rear window repair/replacement - '75 Trade Wind rwnash Windows & Screens 7 06-04-2006 09:51 AM
