Old 03-14-2014, 07:35 AM   #1
VNO
1975 Argosy 24
Germantown , Tennessee
Best Info to Self-Install Air Conditioner
Morning ya'll. I have two very capable folks to install our penguin air conditioner on our '74 Argosy.
Wonder if you can point me to the right thread with the best description of the install, including a discussion on drain tube vs. pan.
Thanks so much. Sure is going to be hot again this summer at Space Camp without it.
Eaglemate is offline   Reply With Quote
Old 03-14-2014, 06:17 PM   #2
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Did you say Space Camp? We go there all the time! We also just installed a dometic Air conditioner. The instructions which came with it were excellent. We bought the additional cup and drain kit.
Skatiero is offline   Reply With Quote
Old 03-14-2014, 06:30 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I did not do mine but have been told by several sources you will need to add some wood framing inside the skin for support
Old 03-14-2014, 07:14 PM   #4
VNO
1975 Argosy 24
Skatiero, that sounds promising! We did the camp last year without air and it was.....rough! Local shops want $1,500.00 for the unit and install, and maybe we will go ahead and give it a shot.
Old 03-14-2014, 10:19 PM   #5
Kyle401's Avatar
1969 27' Overlander
SW , Missouri
Here's a few pictures of the braces that I added when I replaced my gasket last spring. Mine did not have the aluminum channel sides when I pulled it. This is not the original AC so I don't know who engineered the installation, but it didn't match Dometic's instructions.
ID:	207479   Click image for larger version
Kyle401 is offline   Reply With Quote
Old 03-15-2014, 12:45 AM   #6
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
Yikes!!! Is that Wood that I see?!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 03-15-2014, 07:09 AM   #7
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I thought I posted pictures/explanation of this install of a Penguin low profile a/c in my daughter's Minuet once upon a time, but I can't find it. So, here are some pictures of the install:
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 03-15-2014, 07:29 AM   #8
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Many people use wood shims for the a/c braces. I've made up a kit our parts department now sells, consisting of a pair of curved roof bow sections and a pair of Z channel sections. It works better than the wood, and follows the contour of the roof better. It's done by using the bow piece from the wide body trailers, which is not curved as much as the narrow, older trailers, and seems to be a good compromise between the flat a/c base and the curved roof.
Old 04-01-2016, 07:58 AM   #9
1978 Argosy Minuet 6.0 Metre
Fayetteville , Arkansas
A/C brace kit?
Where is this available? Will it work on the 6.0 Minuet?
thanks
Jimmie
j24jaded is offline   Reply With Quote
Old 06-01-2016, 08:45 AM   #10
VNO
1975 Argosy 24
These pictures are incredibly helpful!
Advice Needed: Duo Therm Air Conditioner & Heat Pump BKBroiler67 Furnaces, Heaters, Fireplaces & Air Conditioning 19 07-22-2015 05:40 AM
Can you run both Air Conditioners with the Genset? Keyair Classic Motorhomes 4 08-26-2011 05:32 PM
need air conditioner ally 1965 - 1969 Overlander 2 07-02-2011 09:54 PM
Air compressor silverdream2 Classic Motorhomes 9 06-22-2011 10:29 PM
