Old 12-13-2015, 02:33 PM   #1
1976 31' Sovereign
Caledonia , Michigan
Best air conditioner
Wondering what is the best unit to install?
Ajunghans is offline   Reply With Quote
Old 12-13-2015, 03:57 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
What is your definition of 'best'??
Old 12-13-2015, 05:00 PM   #3
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
IMHO the best A/C unit to get is none at all.
If you can get away with installing a couple of Maxxair fans, one to blow in and another to blow out, you could very well get away without having to buy and maintain an expensive A/C unit. This would also save you quite a bit of weight and decrease water leaks into the trailer.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Isuzusweet is online now   Reply With Quote
Old 12-13-2015, 06:08 PM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Tony obviously does not live in Texas. I have Dometic, Coleman and Carrier low profile. Even though Carrier is no longer making the low profile...it is, by far, the best I have.
Old 12-13-2015, 06:10 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Unless you are doing your camping up north, Fans won't keep you comfortable. The question is 13.5 or 15,000 BTU units. The difference being you can run a 13.5 off generators for a 15 you need shore power. I got a low profile Dometic Penguin. Works good but an AC which sits higher would be a bit more quiet. Isuzusweet is kind of right. Speaking for myself most of the time I don't use the AC, even here in the southwest, but when it's hot out it's really hot and can make the difference between enjoyment and misery.
Old 12-14-2015, 03:58 PM   #6
Dazed and Confused
Isuzusweet's Avatar
Nope, I don't. I live in the GWN and when it does get humid here I just head further north. In the summer the further north you go, the longer the day you have to enjoy.
Cheers
Tony
Old 12-14-2015, 04:10 PM   #7
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I think I'd like those longer days, Tony.
Old 05-16-2019, 11:00 AM   #8
1967 26' Overlander
Austin , TX
I'm trying to decide now between 13,500 and 15,000 for our 1967 Airstream Overlander 26. And I live in Texas. What do you mean by "shore power"?
Farmer Erin is offline   Reply With Quote
Old 05-16-2019, 11:48 AM   #9
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Clear Lake Shores , Texas
Answers
Shore power means being plugged into a 30 amp receptacle. My 67 Overlander was cooled by a 12,000 BTU mini-split unit which was ultra quiet and drew only 11 amps. It was mounted up front but still cooled the trailer nicely except for the bathroom. I would think 13,500 would work well unless it was super hot. We simply opt not to go camping in the height of the Texas summer.
BambiTex is offline   Reply With Quote
Old 05-16-2019, 01:56 PM   #10
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
It is unreasonable to think you can be comfortable in an AS without AC. Fans don't cool the air rather move it at it's current temp in the hopes of evaporating moisture on your skin... In humid climates, that's a no go!
Get a Penguin
Old 05-16-2019, 04:58 PM   #11
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Consider where the condensate goes. Make sure that whatever you buy will work with the existing drain pipe. Water running on the roof all the time during the summer will encourage algae growth on the surface.
I've replace a few with Dometic Penguin, one with Dometic Brisk Air, and a long time ago one with a Coleman. I like the Penguin best.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 05-16-2019, 05:37 PM   #12
2007 27' International CCD FB
San Diego , California
This is a really old thread. The OP likely has made a decision long ago.
For posterity of future users, I did a lot of research here in circa 2018/2019.
The highest rated capacity units are the Atwood Air Command units (now acquired by Dometic). They are rated at 16k-18k output. They are a bit different of an animal in regards to thermostat and condensate collection. But then again, so are the newer Dometics with catch cups vs catch pans that Airstream use to use in the 2000s.
That said, of Dometics formal line of A/Cs, the Blizzard NXT is the "best" in terms of cooling output and airflow. Penguin is best for low profile aesthetics.
Even though all models are rated at 15k BTU, there are meaningful output differences that aren't capture in numbers. Here's some data suggesting detail differences between compressor/fan/refrigerant capacity which would lend to output differences.
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
Tongue Mount Honda eu2200i - Rear Hitch - Underbelly Storage - Blizzard NXT w/ EasyStart - 3" Lift - 6" Fan Controller
pteck is offline   Reply With Quote
Old 05-17-2019, 07:37 AM   #13
1967 26' Overlander
Austin , TX
Choosing Penguin
Thanks for sharing this information. Ultimately, we want to be off-grid so I went with the Penguin II, 13,5000. We'll see how it keeps us cool mid-August.
Old 05-17-2019, 08:43 AM   #14
mikextr's Avatar
1967 26' Overlander
Bugtussle , Oklahoma
@pteck
Wish I had seen your chart before I bought my Brisk II 15K. Looks like NXT is the way to go.
1967 Overlander International 26ft
2006 Porsche Cayenne Turbo S 520hp 530ft-lbs torque 7700lb towing capacity
mikextr is offline   Reply With Quote
Best Info to Self-Install Air Conditioner Eaglemate Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-01-2016 08:45 AM
Best air conditioner? Bing-Bing Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-21-2009 02:38 PM
air conditioner air flow problem strawberryjo Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-05-2006 10:43 AM
