Old 05-02-2015, 07:24 PM   #1
1999 19' Bambi
Phillips , Wisconsin
bambi water heater
Hey folks: We have a 1999 Bambi with a water heater that has a personality of its own. There is a factory note inside the flip-down door that says, "before ordering a new computer board clean the terminals on the connector."
So I clean the terminals, then jiggle and wiggle the four wire connector until the thing finally lights. Many times I have to wiggle and giggle and cajole the thing numerous times before it works. If it's chilly out it usually won't light.
There has to be a better way, so I am asking if any of you have a solution to
this problem. Maybe there is some retrofit that gets the thing to light when you try lighting it. HELP!
Thanks..........RIC
ricnjane is offline   Reply With Quote
Propane Heater or Instant water heater valontjej Plumbing - Systems & Fixtures 1 04-09-2012 08:56 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 08:06 PM
