Old 02-12-2012, 04:33 PM   #1
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
Aux Heat Element Question
I have an 02 AS with the Penguin 11K btu AC with an Aux Heating element installed. The unit has the mechanical controls on the unit shroud. The thermostat does not seem to turn the heating element off when temperature is reached. Is this unit designed for the thermostat to control the aux heat or is it an all or nothing sort of control?
This is the first time I have used the aux heat and have no clue if the thermostat should control the heat function. Common sense says it should but I like to hear from someone who this specific type of unit.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 02-12-2012, 06:14 PM   #2
2002 25' Safari
Images: 11
I found an operating manual for my AC unit. The unit is a penguin 600 series. Believe it or not the owners manual says that the strip heat is not controlled by the thermostat. The heat strip is either off or on. I can't believe this design.
Bud
Old 02-12-2012, 07:16 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Right you are. All manual thermostat controls on direct blow A/C units refer strictly to the cooling section of the unit. If you have a heat pump, it would control that also. Your heat strip is either on or off. You will find that they do not provide a lot of heat, but will take the chill out of the air.
I had a couple of roof air units in a motor home for 5 years and found the heat strips to be just north of worthless for heating applications.
Heat from A/C unit GaCamper LP Gas, Piping, Tanks & Regulators 4 01-15-2012 06:08 AM
Duo-therm and furnace question... NoMoSOBs Furnaces, Heaters, Fireplaces & Air Conditioning 13 10-21-2011 09:17 AM
Blasphemous question woytovich General Repair Forum 15 04-09-2011 08:36 AM
Had the honor to step inside a 1962 Bambi this weekend and fell in LOVE with the heat J5MM LP Gas, Piping, Tanks & Regulators 9 03-14-2011 02:52 PM
Heat Pumps Brianv512 Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-19-2011 05:15 PM
