Old 05-28-2014, 03:28 PM   #1
2006 30' Classic
Milton , Florida
Atwood hydro flame 8500-IV Furnace
We are currently on the road in our 2006 30 ft. Classic. It is equipped with an Atwood hydro flame 8500-IV series furnace (propane), a 13,500 BTU Duo-therm Penguin heat pump, and a Duo-therm Comfort Control thermostat.
Several days back, while in Ogden, Utah, we were running the air conditioner and the blower for the propane furnace cycled on when the thermostat was set to "cool". The furnace did not ignite, the blower (fan) just started and stopped several times.
Does anyone have an idea as to what might cause this to happen?
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 05-28-2014, 06:33 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
You have a 'confused' (yes, it's really a technical term) thermostat. You need to do a re-set.
If you can't find the procedure, PM me and I'll give you the procedure.
Old 05-29-2014, 07:57 PM   #3
2006 30' Classic
Milton , Florida
Thermostat Re-set
Thanks for the timely reply. After making the original post, I thought about what was common to the furnace and the heat pump and came up with the thermostat.
From one of your original posts, I had printed and filed the re-set procedure for the CCC. I dug it out and performed a re-set on the thermostat. So far, the problem has not resurfaced.
Is there anything in particular that tends to happen to "confuse" the thermostat and create such problems as the one that I encountered?
F. A. Meloy
2006 30' Classic
Old 05-29-2014, 08:40 PM   #4
lewster's Avatar
Nope! Probably nothing you did. They can often have a mind of their own.
Atwood Furnace, Hydro Flame, Land Yacht Clipper masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 6 01-27-2012 10:45 PM
hydro flame won't flame 123f5 Furnaces, Heaters, Fireplaces & Air Conditioning 2 11-12-2010 09:05 PM
thermostat atwood hydro flame dhe9 Furnaces, Heaters, Fireplaces & Air Conditioning 3 09-05-2010 07:31 PM
OK, Atwood Hydro Flame 8012 12K just got expensive ronstory Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-13-2009 10:50 AM
