Old 10-11-2010, 08:37 PM   #1
1998 34' Cutter Bus w/slide
hull , Quebec
Atwood hotwater tank replacement
I need to replaced my hotwater tank the unit part number is GH6A-8E would the model GCH6A-10E fit in as this one is also electric heated.Would anybody able to help me on this.
Thank You
poloharvey is offline   Reply With Quote
Old 10-11-2010, 11:24 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
The size of your current unit:
12 1/2 H x 16 W x 16 7/8 D
The size of the replacement your planning:
Old 10-12-2010, 12:14 AM   #3
hull , Quebec
Well it seem like the perfect fit.I am not wired for the elctrique part is it a big job to bring to the tank to get it to work on electricity
Thank You
Old 10-12-2010, 12:51 AM   #4
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
I just replaced my tank, keeping the old frame and electronics, etc. The tank was about $160 - saving me about $400. Not sure if that is what you are talking about or not.
My old tank had some sort of weeping leak that was getting worse and worse. The new tank has the Styrofoam surround versus the old fiberglass insulation.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 10-13-2010, 01:31 AM   #5
hull , Quebec
Yes that would be a solution for me also do you have the part number for that replacement tank
Thank You
atwood DSI Solenoid Replacement tkowalyk Water Heaters, Filters & Pumps 2 05-25-2009 05:42 PM
2003 safari ss hotwater heater brad_casie Furnaces, Heaters, Fireplaces & Air Conditioning 7 03-09-2009 08:06 PM
Replacing Hotwater heater CANADIAN EH! Water Heaters, Filters & Pumps 7 08-08-2007 02:50 PM
Atwood water heater pilot replacement ? Davis Water Heaters, Filters & Pumps 6 04-23-2007 04:39 PM
Bowen/Atwood LP to Atwood LP/ELEC./DSI? 65 overlander Electrical - Systems, Generators, Batteries & Solar 9 12-05-2005 07:10 PM
