Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 10-06-2009, 03:23 PM   #1
Commercial Vendor
Moonstruck's Avatar
Profile:  1986 31' Sovereign
Sherfield English , Hampshire
Send a message via MSN to Moonstruck Send a message via Yahoo to Moonstruck
Atwood Heater - Red light stays on!
Hi Guys!
full-time living in an Airstream is a little different. I've just RETURNED from a weekend away at my girlfriend's to find my water heater pretty much dead except for from the ignition light in the bathroom. The heater is only a year old, very clean and no corrosion.
After reading a few troubleshooter pieces I'm coming to the conclusion that it's the board. That could just be wishful thinking as I did take the precaution of getting a replacement on my last spares shipping.
I could fit the board and see what happens but I'll wait until the morning as it's dark here and tipping with rain.
Can anybody suggest/confirm my diagnosis?
Marc
btw, I recently attended a UK Airstreamers meet over here. Pictures here
http://www.silvertwinkie.co.uk/MyWeb...lery/index.htm
Silvertwinkie
Hampshire, UK
Moonstruck is offline   Reply With Quote
Old 10-06-2009, 03:40 PM   #2
Profile:  2007 25' Safari FB SE
Livingston , Texas
Marc,
try this first (since this won't cost anything): remove, clean and reinstall the little contact points found just inside the burner tube, as well as its mounting area (to make sure it is getting a good ground). If a spark is not produced, the starting sequence will shut down (turning on the red light)......I have to perform this little ritual at least once a year.
fmrcaptevil is offline   Reply With Quote
Old 10-06-2009, 03:56 PM   #3
aluminauti
whitelight's Avatar
Profile:  Where we , Park it!
Just thought that I'd ask, but our red light comes on our water heater when we're out of propane!
Check out that any other propane appliances are working properly.
whitelight is offline   Reply With Quote
Old 10-06-2009, 03:57 PM   #4
aluminauti
whitelight's Avatar
P.S cool pics! Glad to see vintage units on the other side of the pond!
Old 10-06-2009, 04:29 PM   #5
Commercial Vendor
Moonstruck's Avatar
Thanks for the suggestions guys!
The trouble-shooting I've checked was peppered with suggestions about corroded terminals. As I said the unit is less than a year old and very clean but I have removed/replaced all the "spade" terminals and I will check the burner connections before proceeding. My first thought on my return was the gas but I've cooked a curry since and it's all going strong.
btw, I've also fired up the Suburban NT 30 furnace to confirm that the 12 volt amperage and the gas pressure are fine.
As I've said, the unit seems dead. I've checked the connections with the power on but there's not a hint of arcing except from the fuse on the board.
Marc
Silvertwinkie
Hampshire, UK
Atwood Water Heater Problem (pilot light) sugarloafin' Furnaces, Heaters, Fireplaces & Air Conditioning 10 03-06-2009 10:37 PM
Bathroom Atwood panel w/center red light RLS Water Heaters, Filters & Pumps 5 10-01-2008 02:34 PM
Stays lit-water heater pilot light doorgunner Water Heaters, Filters & Pumps 4 07-01-2008 07:15 PM
Soot from Atwood water heater pilot light nickcrowhurst Water Heaters, Filters & Pumps 4 12-10-2007 01:29 PM
red light on water heater aeriqua Water Heaters, Filters & Pumps 6 01-10-2006 05:21 AM
