Furnace
Have you done any maintenance on it ie. cleaning out the camber? One thing you might check for dust in the unit. If you have excessive dust that will trap the" sail switch" and stop the unit from igniting. It is a safety feature. Check you manual for location of the switch on your unit. if you know you have gas to the furnace then it could be one of two things.
Check you your control board your manual will address the codes for a blinking, and point to a specific area, you should see a small diode light you may have failed circuit board .
The electronic igniter,( mine had a crack on the ceramic insulator and this would short out causing the unit not to fire). You should hear the igniter ticking several times prior to ignition, if you don't hear that ticking then look there.
Laurence
