Old 06-29-2009, 03:08 PM   #1
1977 31' Sovereign
New York , New York
Atwood equivalent for Bowen G6-10B?
Hi - does anyone know the current Atwood equivalent for a Bowen G6-10B from my 1977 31 foot Sovereign?
Thanks in advance
Evan
Email me directly (evanelkin@yahoo.com) too if you don't mind if you decide to post a response to this thread
Evanelk is offline   Reply With Quote
Old 06-30-2009, 04:33 AM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Evan - any 10 gallon Atwood is a replacement for your unit. The gas only would be what you have now. If you go gas/electric you'll need to run a 120v line to the panel box. Installing a new one may require some modification to the incoming gas line to line it up. You won't be able to use your current stainless door on the new unit without some pretty extensive modifications. Now may be the time to install a bypass kit if you don't have one now.
All in all not a bad project as Airstream projects go.... Have fun....
'66 TW. Bowen OUT, Atwood IN. FreshAir Water Heaters, Filters & Pumps 14 08-08-2008 08:18 PM
Bowen or Atwood Sundance Water Heaters, Filters & Pumps 2 07-11-2007 04:22 PM
Bowen/Atwood LP to Atwood LP/ELEC./DSI? 65 overlander Electrical - Systems, Generators, Batteries & Solar 9 12-05-2005 06:10 PM
New Atwood water heater old Bowen door vent problem 63air Electrical - Systems, Generators, Batteries & Solar 0 08-22-2005 02:56 PM
Atwood Bowen anode rod? Moonshot Water Heaters, Filters & Pumps 3 11-11-2003 07:37 AM
