Old 10-04-2012, 10:09 AM   #1
1977 Argosy 24
Milltown , Wisconsin
Armstrong TR25-10 help needed
The compressor on my Armstrong AC worked for a while and it blew cold. Now The compressor just hums. From what I have read, I may need new start and/or run capacitors. Does anyone know the MFD values of the 2 capacitors so I can buy them?
ventport is offline   Reply With Quote
Old 10-04-2012, 11:04 AM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
You would be better off checking the values of your existing capacitors. Both the compressor and fan motor have been replaced in my Armstrong, and each required a different value capacitor than the original equipment.
Your unit may not be able to use the capacitors mentioned by others.
Tom
Old 10-04-2012, 11:27 AM   #3
1971 31' Excella 500
Lake worth , Florida
Tom, were did u find a compressor for your unit?
Natestravels is offline   Reply With Quote
