Old 04-07-2010, 04:43 AM   #1
1984 31' Excella
Norfolk , Virginia
Images: 11
Armstrong Thermostat
I'm looking for an Armstrong thermostat. My daughter has a 72 Tradewind. We finally got the old AC working after replacing the bad control circutry, however some previous owner replaced the original thermostat with a honeywell that dosent have the two speed fan option.
Anybody got one?
Beginner
Beginner is offline   Reply With Quote
Old 04-07-2010, 05:27 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Why would you want to?
The second speed isn't that critical. I replaced our 2 speed thermostat with one like you have because the original was wildly inaccurate at best. The modern thermostat shuts the whole unit down rather than just the compressor, when it reaches the set temp. When off, it's much quieter in the trailer, and we didn't miss "high fan" at all.
Old 04-07-2010, 06:27 AM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Dometic 3106995.065 Analog Thermostat Cool Furnace RV : eBay Motors (item 280488834783 end time May-04-10 17:47:36 PDT)
Old 04-07-2010, 07:49 AM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I installed a switch inside a cabinet to switch fan speeds since my digital thermostat did not provide for 2 speeds. Crude, but it works
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
A/C Thermostat Devoman Furnaces, Heaters, Fireplaces & Air Conditioning 7 06-01-2014 11:42 PM
HELP, On Armstrong AC Thermostat mburgess1431 Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-27-2012 01:07 AM
thermostat ? dhe9 Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-02-2010 05:08 PM
Thermostat On/Off 77Overlander Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-18-2009 05:31 PM
Thermostat Lost 1975 Armstrong Collusion Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-28-2007 05:31 PM
