Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 04-16-2007, 09:30 AM   #1
Sundance
Profile:  1973 26' Argosy 26
Devils Lake , North Dakota
Cool Armstrong Shroud Mod.
Well I just ordered the Tuff-Maxx shroud and am going to
retro-fit it to the Armstrong on the 73' Argosy. The dimensions
are correct other than the length, and specifically the nose.
I am going to trim the existing bottom shroud piece (which is in
great shape) by 1" (or so) and fabricate "filler" pieces
to fill whatever small void there is in the front corners.
Before assembling I am going to paint the existing bottom
shroud with one of the new plastic paints that actually "melt"
into the substrate.
Armstrong Bottom Shroud Dimensions:
Length: 42 3/4" (aprox.)
Width: 29" (approx)
Height: 12 (approx.)
Tuff-Maxx Top Shroud Dimensions:
Length: 41 5/8"
Width: 29 3/8"
Height: 12 3/4"
I'll keep you posted and post pics along the way.
Sundance is offline   Reply With Quote
Old 04-17-2007, 03:21 PM   #2
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Sounds cool, post pics if you can!
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'77 20' Argosy MH (Peanut)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
AC SHroud rheadhuntress Parts Archive 4 04-19-2004 11:38 AM
True story:NEIL ARMSTRONG 53flyingcloud Off Topic Forum 7 11-28-2002 05:50 AM
replacement a/c shroud? roof vents? Dave Cole Furnaces, Heaters, Fireplaces & Air Conditioning 7 10-03-2002 02:06 PM
Removing the Armstrong AC unit FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 11 08-02-2002 12:10 PM
Check your aging A/C shroud Jim Clark Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-25-2002 11:30 PM
test
