Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 07-01-2004, 07:39 PM   #1
Gino
Profile:
Armstrong freon charge
78 soveriegn inter land yacht...........
Can the freon be replaced in the armstrongs with the modern r-34 gas or
r-22 or should I find r-12 to do the job with?
I may add, r-12 is getting very difficult to find and quite pricy.
The newer gas would be of a benefit because if the problem happens again it will be a whole lot easier to deal with.
I want to keep this unit as it is a rooftop freezer box!
I wish my homes AC worked as well as this almost 30 year old unit does!
Gino is offline   Reply With Quote
Old 07-02-2004, 05:03 AM   #2
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
Welcome to the forum!
The specification tag on my '67 Armstrong specifies R-22. Do you have some reason to think your unit does not have the same?
Old 07-02-2004, 08:52 AM   #3
mcneon
mcneon's Avatar
Profile:
Just happened to see a Google ad at the top of this thread:
http://autocool-refrigerants.com/
Their website mentions an R-22 replacement product.
No connection, yada, yada,
mcneon is offline   Reply With Quote
Old 07-02-2004, 12:25 PM   #4
69 Silverback
69 Silverback's Avatar
Profile:  1969 27' Overlander
Firth , Nebraska
Gino,
R-12 &r-134a are both for automotive use only. R-22 & it's replacement R-410 are for small appliances @ rv airconditioners , residential a/c , dehumidifiers, etc.
You can NOT use r-12 or 134a in place of r-22. It is a compatability point. You also can not mix different refrigerants. Again because of compatability. Your Armstrong a/c would use r-22. By EPA laws only certified refrigeration service persons may handle it.
By mixing refrigerants you not only would do serious damage to the unit but also create a mess. Serious hazard, a mixture that can not be reclaimed & possiable health injury.
These are only a few reasons this should only be handled by a licensed tech.
In short , take it to an RV service dealer!
Good luck, Loren
69 Silverback is offline   Reply With Quote
Old 07-02-2004, 01:18 PM   #5
Gino
Profile:
I never looked to see what the charge was.........
I have a tech that will service the unit with r-22.....................
Thanx for the replys folks as the information was needed before we went any further.
Silverado trailer charge line Safari Tim Towing, Tow Vehicles & Hitches 11 06-24-2004 08:57 PM
Can I Trickle Charge into the 12V Wall Jack? westeagle Electrical - Systems, Generators, Batteries & Solar 5 01-21-2004 04:19 PM
batteries wont hold charge Lido&Linda Airstream Motorhome Forums 13 10-26-2003 03:08 PM
True story:NEIL ARMSTRONG 53flyingcloud Off Topic Forum 7 11-28-2002 05:50 AM
Charge Wizard - Help! dmreilly10000 Electrical - Systems, Generators, Batteries & Solar 6 11-15-2002 04:37 PM
test
