Old 07-05-2014, 03:15 PM   #1
1977 31' Excella 500
plano , Texas
Question Armstrong cutting out during daylight hours
I have the original Armstrong on my 77 excella 500. It is parked in the sun. During the heat of the day, the compressor will run for about 30-60 seconds and then make a "loaded" sound and then cut out. Once the sun goes down, it functions just right and cools the trailer perfectly. Unfortunately, the trailer is 60 miles away. After reading other posts, I am not certain if it is the run capacitor or not. Heck, it sounds like it could also be the external fan. I will probably just buy some parts in speculation of the fix prior to my next trip this week. Any suggestions? My voltage in the trailer is 111v even while the compressor is running.
Thomas
tschat is offline   Reply With Quote
Old 07-05-2014, 03:23 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
111 volts is pretty low, in my opinion. I'd check all the electrical connection, first thing.
Cutting Out Damaged Flooring? Roadrunner Repairing/Replacing Floor &/or Frame 4 11-08-2012 03:57 PM
Water Pump cutting out DaveT Water Heaters, Filters & Pumps 3 02-04-2011 09:41 AM
454 cutting out choctawmel Mechanics Corner - Engines, Transmission & More... 43 03-14-2009 07:40 AM
Daylight Savings Time azflycaster Off Topic Forum 11 03-09-2008 11:52 AM
Daylight Savings '07 rickandsandi Off Topic Forum 17 03-10-2007 11:45 AM
