Old 03-17-2009, 10:05 AM   #1
1973 25' Tradewind
Fort Lauderdale , Florida
Armstrong compressor needed
Trying to keep my Airstream original, does anyone now where a good compressor can be found.
Tanks in advance,
Mark
lexusparts is offline   Reply With Quote
Old 03-17-2009, 10:09 AM   #2
Tanks in advance,
Mark
Try W. W. Grainger.
Old 03-17-2009, 05:22 PM   #3
1973 25' Tradewind
Thanks Andy, your help is very appreciated
Mark
Old 03-17-2009, 05:33 PM   #4
Mark
Mark.
If you do the work, then the price is not bad.
If you are going to have someone do it for you, the total cost may exceed that of a new AC.
Also, check the start and run capacitors and the start relay, before you invest in a compressor.
Old 03-18-2009, 07:26 AM   #5
1973 25' Tradewind
The only reason that I would consider replacing the compressor is that my son is an A/C tech and will do the work, The A/C worked well up to 2 months ago but lost the oil and freon out of the bottom of the compressor because a rust spot.
I will check with Grainger today.
Old 03-22-2009, 07:11 PM   #6
1973 29' Ambassador
Troutville , Virginia
Have a complete 73 ac that was working on a 20 ft ambassador - price cheap - get it out of my garage.-- Jim J i .e. you pay shippin - located in sw Virginia
Jim Johnson is offline   Reply With Quote
Compressor ideas needed .... Help! GlenCoombe Mechanics Corner - Engines, Transmission & More... 16 05-01-2008 09:45 AM
new compressor norbert General Repair Forum 2 04-02-2008 09:47 PM
Armstrong AC parts and advice needed russell scott Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-16-2005 02:55 PM
Armstrong AC parts needed hummerdinger Furnaces, Heaters, Fireplaces & Air Conditioning 3 08-24-2005 03:26 PM
