Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 07-24-2004, 08:01 PM   #1
Kurt & Eve
Profile:
Armstrong Air Conditioner
We have 27 ft 1972 Overlander with a Armstrong air conditioner that quit working last year. The air conditioner was working , then it began to leak drops of water inside the trailer before it quit blowing cold air. Now it just blows air. Any help would be appreiciated.
Kurt & Eve is offline   Reply With Quote
Old 07-24-2004, 08:06 PM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
There are a number of things that could cause the unit to stop working.
Couple of questions:
Do you have a wall mounted thermostat?
Does the blower still work?
Depending on the answers there are many options to how to fix it. The Armstrong units are normally tough as tanks and can be fixed by a normal AC guy.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 07-24-2004, 08:18 PM   #3
Kurt & Eve
Profile:
Hello Brent G
Yes it does have a wall mounted thermostat and yes the blower still works.
Old 07-24-2004, 08:21 PM   #4
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
Originally Posted by Kurt & Eve
Hello Brent G
Next question, can you hear the compressor start when you turn the unit on? Or does it just click and just the fan continue to run?
Old 07-24-2004, 08:28 PM   #5
Kurt & Eve
Profile:
I will get back to you tomarrow (July 25) on that one.
Old 07-24-2004, 10:01 PM   #6
dbtolman
The Sh*tt*r's Full!
dbtolman's Avatar
Profile:  1970 27' Overlander
lewisville , Texas
Is there an easy way to tell if this is the AC unit in my 70 overlander?
dbtolman is offline   Reply With Quote
Old 07-24-2004, 10:09 PM   #7
thenewkid64
Just a member
Images: 21
Does the shroud inside say Armstrong on it?
Armstrong seems to be the only brand that uses a remote thermostat that were installed in the 70's.
Brett G
Old 07-24-2004, 10:47 PM   #8
dbtolman
The Sh*tt*r's Full!
dbtolman's Avatar
lewisville , Texas
Hmmm.... Have to drive out to see it at storage... It's got the remote thermostat though...
Particularly interested in this thread since mine drips water (condensation) from the shroud inside right now...
Old 07-25-2004, 08:26 AM   #9
overlander63
Rivet Masher
L.A. , California
Here is a link to my trailer while it still had the OEM Armstrong unit on it. If yours looks like this, then you know what you have.
http://www.airstreamphotos.com/photo...cat/500/page/2
Old 07-25-2004, 08:34 PM   #10
Kurt & Eve
Profile:
Hello Brent G
Couldnt't get to the trailer today. Will try again next weekend. Thanks for your help
Old 07-25-2004, 08:37 PM   #11
robandzoe
robandzoe's Avatar
Profile:  1958 30' Sovereign of the Road
1965 17' Caravel
Plymouth , New York
Images: 26
Cut up
This trailer is going to be cut up within the next two weeks. It has an Armstrong AC on it. It's located in NE North Carolina, about 2 hours from Raleigh, in Hubert, zip code 28539.
http://www.airstreamphotos.com/photo...sort/1/cat/500
Rob
Rob, Zoe', Stanton, Bryce and Braedon Baker
WDCU President
Do you Listen to the www.theVAP.com
Plymouth, NY 13832 WBCCI #2820
Courtesy parking (607) 334 4960
58 30' Sovereign of the Road:
http://sweetsovereign.blogspot.com
65 17' Caravel, 54 22' Safari, 1959 Buick Electra
robandzoe is offline   Reply With Quote
Old 07-25-2004, 11:31 PM   #12
JohnG
JohnG's Avatar
Profile:
Rob
Does that AC work? Wouldn't want to drive out to get it or even pay shipping for it unless it for sure works?
What else is in that trailer that is salvageable? Can you post some pictures?
Just adding my 2˘ worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 07-31-2004, 03:51 PM   #13
Kurt & Eve
Profile:
Hello Brent G
The cannot hear the compressor start and the ac unit does not make the clicking sound, but the fan does run.
Old 07-31-2004, 04:13 PM   #14
thenewkid64
Just a member
Images: 21
Hello Brent G
If you take the cover off the thermostat you should have 12-14 volts at the screws. If not, then the transformer, under the shroud on the roof, will need to be replaced. I have not replaced one, but I know DavidZ here on the forum has replaced his. The reason for the transformer is to feed the relays that energize the compressor. You could also be in need of a starter capacitor, but if it were a cap then you have a dip in the sound of the fan as the compressor tries to start.
Brett G
how to install a new air conditioner Steve Wong Furnaces, Heaters, Fireplaces & Air Conditioning 29 03-24-2007 12:09 PM
Armstrong AC air filter sander17 Furnaces, Heaters, Fireplaces & Air Conditioning 1 05-12-2004 09:22 AM
Original Armstrong furnace Co Air conditioner question. Mark K Airstream Motorhome Forums 3 09-20-2003 10:04 PM
Air Conditioner Question/Problem??? pscottn Furnaces, Heaters, Fireplaces & Air Conditioning 6 08-23-2003 11:21 AM
For Sale 13,500 BTU Air Conditioner GoldFever Parts Archive 4 08-09-2003 10:11 PM
test
