Old 08-09-2004, 11:40 AM   #15
Originally Posted by robandzoe
This trailer is going to be cut up within the next two weeks. It has an Armstrong AC on it. It's located in NE North Carolina, about 2 hours from Raleigh, in Hubert, zip code 28539.
http://www.airstreamphotos.com/photo...sort/1/cat/500
Rob
Just found this post and was not sure if it was to late, but I am looking for a shroud for an Armstrong A/C unit and a Suburban brand NT-20 or NT-30 furnace. Do you have either item available?
Todd & Craig
The Burly Boys
New to the world of Airstreaming, but not to the world.
Burlyboys is offline   Reply With Quote
Old 08-09-2004, 05:30 PM   #16
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Armstrong not running
Kurt & Eve,
What is the latest on your AC situation?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-09-2004, 07:15 PM   #17
AirConditioner's Avatar
I'm working on fabricating an aluminum shroud for the Armstrong unit and will have it done in a week or so. If your interested let me know and I'll keep you posted on the design and cost. I thought of replacing mine with fiberglass one but I'm more interested in durability and looks. One tree branch and the fiberglass is a goner. And I like the idea of polishing it up to match my '72 Overlander.
AirConditioner is offline   Reply With Quote
Old 08-16-2004, 04:06 PM   #18
Sorry to take so long getting back to you. I would be interested in finding out the details on the aluminum shroud. I understand that there was only one style of Armstrong A/C unit used. Do you know if that is in fact true? Anyway let me know once you have the costs down..
Todd & Craig
The Burly Boys
Old 08-18-2004, 11:12 AM   #19
Sorry to tell you there were at least 4 models of shrouds and I presume at least that number of different Armstrong A/C models.
The aftermarket different shrouds can be found pictured at Inland RV website on the parts list.
There is a data plate under the shroud on the galvanized unit. My model Armstrong is the TRH-25-14. and the shroud that I have (identified by looking at my old one and comparing to Inland's pictures) is Inland #69831, which they say is for years 76,77,78,and 79.
I do not know whether Andy has a way to ID shroud by model number or not.
But if I did not have a shroud to compare, I'd be very sure which one to order before doing so. Return would be costly and damage prone I suspect.
roadeo is offline   Reply With Quote
Old 08-18-2004, 12:52 PM   #20
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by roadeo
... Return would be costly and damage prone I suspect.
Probably costly, but I hope not damage prone - I checked with InlandRV the other day about a new shroud for my Armstrong unit. Shipping was $115 and the handling, apparently due to it's size, was an additional $25.
I would hope a $25 container would be good for more than one use.
Tom
Old 08-18-2004, 01:29 PM   #21
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I have done some reinforcing as you described, it works well.
You need to lightly sand the surface before applying the resin. The cloth should be in the smallest pieces you can handle since the spots that normally need work are compound curves and corners. You want the cloth to stay flat, not bridge, big pieces will tend to bridge in corners. Over curves the big sections are fine.
If you have holes I recommend using some blue masking tape on the outside. This will allow the resin to fill the void, and with a bit of sanding afterword offer a nice surface to repaint. Be sure to remove the tape in the first hour or so after layup.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 08-21-2004, 10:13 AM   #22
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by tcwilliams
I would hope a $25 container would be good for more than one use.Tom
Tom, unfortunately the $25.00 is a surcharge for oversized/overweight items, and not for a better shipping container.
This is from personal experience, Andy would just be passing along an additional fee. The box it comes in may be a little more heavy-duty, but that is just because it is bigger, and the shroud is more fragile.
Old 08-21-2004, 02:29 PM   #23
TomW's Avatar
1967 26' Overlander
That was not the way his worker explained it to me. The $115 charge handled the oversized/overweight category, and the $25 charge was to put the "bulky" item into what was apparently a specially made box. It sounded like the shrouds sit on the shelf unboxed.
I appreciate your personal experience, but that's what I was told.
I still think the total S&H charges are extreme for the price & actual weight of the particular item. But Andy is in the catbird's seat with this particular item, and I have no problem with his marketing strategy. With vintage Airstreams, "You play, you pay"
Tom
Old 09-21-2004, 07:00 AM   #24
TomW's Avatar
1967 26' Overlander
I'm working on fabricating an aluminum shroud for the Armstrong unit and will have it done in a week or so. If your interested let me know and I'll keep you posted on the design and cost...
Any pictures to share yet?
How to install a new air conditioner? Steve Wong Furnaces, Heaters, Fireplaces & Air Conditioning 30 05-02-2017 03:12 PM
Armstrong AC air filter sander17 Furnaces, Heaters, Fireplaces & Air Conditioning 1 05-12-2004 08:22 AM
Original Armstrong furnace Co Air conditioner question. Mark K Airstream Motorhome Forums 3 09-20-2003 09:04 PM
Air Conditioner Question/Problem??? pscottn Furnaces, Heaters, Fireplaces & Air Conditioning 6 08-23-2003 10:21 AM
