Old 07-26-2013, 07:28 AM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Armstrong AC wiring diagram
There are 4 wires going into my 1975 oem Armstrong Air Conditioner wall mounted thermostat: green, red, black and brown. The red seems to be the + wire. I need to figure out the others. Anyone have a wiring diagram? Any suggestions on a Air Conditioner wall thermostat replacement?
Marshall
Old 07-26-2013, 11:07 AM   #2
mopariac's Avatar
1972 29' Ambassador
Weatherford , Texas
1972 Diagram...close
Hopefully this will help. The diagram shows a white wire instead of the brown but would have to think they would go to the same place on yours...hope it helps.
Tharon
mopariac is offline   Reply With Quote
Old 07-26-2013, 02:49 PM   #3
Lumatic's Avatar
1993 34' Excella
Images: 16
This is the sucka. more to follow
Old 07-26-2013, 02:53 PM   #4
Lumatic's Avatar
1993 34' Excella
Images: 16
Photo 2
Old 07-26-2013, 02:54 PM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
Old 07-28-2013, 10:11 AM   #6
Lumatic's Avatar
1993 34' Excella
Images: 16
Maybe this will ring a bell for someone. These are the labels on the thermostat shown in the last photo above:
The green wire goes to a connection labeled G!
The black wire goes to a connection labeled G2
The brown wire goes to a connection labeled Y
The red wire goes to a connection labeled R
G1 is on the left side of the thermostat. G2, Y and yellow are on the right side. My problem is figuring out what functions on the thermostat do these connections relate to. The wiring diagram ABOVE shows these wires, but I can't figure out what they do or what switch they are connected with as the circuitry is hidden.
At the bottom of the thermostat are 2 switches: on the left LO/ HI (Fan) on the right COOL/ OFF
Old 07-28-2013, 04:18 PM   #7
1971 27' Overlander
mankato , Minnesota
Im working on the same thing to day. Here is what I found. Brown wire to the Y.
Red to R, green wire is low fan speed , black is high speed. green or black go to
G on thermostat depending on speed you want.
Dave.K is offline   Reply With Quote
Old 07-28-2013, 05:30 PM   #8
Lumatic's Avatar
1993 34' Excella
Images: 16
So red is +?
What does brown/yellow do?
Does the circuitry switches combine both black and green to give you high or would that fry the wires?
Old 07-28-2013, 06:31 PM   #9
1971 27' Overlander
mankato , Minnesota
Ok Yes Red is + that goes to red on your new thermostat . The Brown goes to the Y on the thermostat . green or black do not wire them both together. Depending on the speed you want the fan to run. On mine black is high speed. I went manards & bought a cheep lux thermostat for $15.00 works well.
Old 07-28-2013, 06:36 PM   #10
1971 27' Overlander
mankato , Minnesota
Sorry I forgot to tell you brown turns on the compressor .
Old 07-28-2013, 07:34 PM   #11
Lumatic's Avatar
1993 34' Excella
Images: 16
So with your cheep lux you only run your fan on high? No high/low fan switch right? Is your $15 thermostat a furnace thermostat? Or a "close on rise" thermostat meant for AC? If it is a furnace thermostat, (if I am understanding the difference between AC and furnace thermostats) it sounds like it can only be used the turn the AC on manually. Sounds like with a furnace thermostat the AC won't automatically shut on and off in relation to temperature, automatically turning on when the temp gets too high and automatically shutting off when the temp gets too cold?
Old 07-28-2013, 08:06 PM   #12
1971 27' Overlander
mankato , Minnesota
It is a normal home thermostat that runs heat & A/c you have to chose high or low speed when you wire it . It works just like in your home it should shut off on it own. Turn it to cool & set your temp. If all else fails call an A/c repair company & have them wire it.
Good luck
Old 07-28-2013, 09:16 PM   #13
jmpratt's Avatar
1969 29' Ambassador
Liberty Township , Ohio
If you look at my posted pictures, I've included an entire Armstrong manual. It has a wiring diagram. I don't know if its your model, but it might help.
jmpratt is offline   Reply With Quote
