Old 09-09-2007, 10:58 PM   #1
Siamese66's Avatar
1976 25' Tradewind
Seattle , Washington
Armstrong AC Shroud Painting?
I have a replacement ac shroud for my 76 Armstrong ac from Inland Rv. Could anyone tell me how they went about painting their ac shroud? Was there straight paint or primer and paint? What color and type of paint is the best to use? Any information is greatly appreciated.
Siamese66 is offline   Reply With Quote
Old 09-10-2007, 05:20 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Is it raw foberglass, or is it already white?
If it hasn't been painted, scuff the surface, wipe it down with surface prep cleaner (auto parts store), and paint with a good satin paint, like Krylon Fusion white satin. Obviously you don't want gloss paint up there, it would look odd.
Old 09-10-2007, 06:06 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I think the shroud for that year was thermal formed ABS plastic. You might look at the GE plastics Website. They now own and sell the largest amount of ABS plastic. Use only the recommended type of primer as most automotive paints solvents will destroy ABS.
Old 09-10-2007, 07:45 AM   #4
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
The replacement shroud we bought from Andy appears to have some kind of coating on it, so we painted it with a good quality enamel only. It's been several years since we painted, and it seems to be holding just fine.
Lynn
WBCCI 21043
Old 09-10-2007, 10:10 AM   #5
Lee Pace's Avatar
After a thorough cleaning, we used spray epoxy paint. It has been on for over a year and still looks great.
Good luck,
Gloria Pace
72 Sovereign
Greenville, Tx
Lee Pace is offline   Reply With Quote
Old 09-11-2007, 04:01 PM   #6
Well Preserved
1993 21' Sovereign
I know the sroud Inland sells is Fiberglass, the original was plastic, and tends to disintegrate.
Old 09-11-2007, 04:16 PM   #7
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Clarification
Originally Posted by overlander63
... the original was plastic, and tends to disintegrate.
... In ultraviolet light (UV light)... Like what comes from the sun.
The original is ABS plastic, the same stuff a lot of plumbing is made from. Most plumbing never sees the sun, and hence, does not disintegrate.
Keep your plastic shroud painted to keep the sun from taking it's toll on it.
Tom
Old 09-11-2007, 05:21 PM   #8
Tom
Tom.
Our AC shrouds are made with fiberglass, and then gel coated white.
Makes them very easy to paint.
Old 09-11-2007, 05:28 PM   #9
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I also bought a shroud from InlandRV for my 1971 TadeWind. After ftting, trimming and drilling it, I took it back apart and farmed out the paint job to a One Day Paint and Body. I had mine painted a bright metallic silver, which made it somewhat less obtrusive to look at on top of a silver trailer. I left the aluminum banding in it's natural state, just cleaned it up with some alloy wheel cleaner. Here is what that looks like:
Uwe
www.area63productions.com
Old 09-11-2007, 05:56 PM   #10
AC Shroud
Uwe.
You have a 1971 Airstream, but you don't have a 71 AC.
The shroud you have is for a 1973 to 1975 Airstream AC.
Back then, many dealers ordered trailers with no AC and sold them that way.
Then perhaps in a year or two, that owner or a second owner would install a current model AC.
That was very common in the early 70's. It was very easy then to see, as an example, a 71 or 72 Airstream, with a 73 AC.
Just wanted others to know that a true 71 AC shroud, does not look like yours.
Old 09-11-2007, 06:06 PM   #11
Well Preserved
1993 21' Sovereign
Here is a 71-72 Armstrong a/c on an Argosy, but they are the same unit:
Old 09-11-2007, 06:11 PM   #12
TomW's Avatar
1967 26' Overlander
My post that you quoted was on the original shroud
Tom.
Okay.
So how does your non-original shroud do in direct sunlight without easy to apply paint?
I would suspect "well", but why make them quote, "easy to paint"?
Tom
Old 09-11-2007, 06:24 PM   #13
Well Preserved
1993 21' Sovereign
Okay.
Tom
They are as "easy to paint" as the fender of a 1974 Corvette.
The mailman should be bringing one to me soon, I'll let y'all know for sure then.
Old 09-11-2007, 06:26 PM   #14
TomW's Avatar
1967 26' Overlander
What am I missing?
... I'll let y'all know for sure then.
Why are you painting it? Will it not arrive white-in-color?
Tom
Replacing AC Shroud - Clean Armstrong Too? montanaandy Furnaces, Heaters, Fireplaces & Air Conditioning 5 06-02-2013 10:03 PM
Armstrong Shroud Mod. Sundance Furnaces, Heaters, Fireplaces & Air Conditioning 1 04-17-2007 02:21 PM
ac shroud rebel beck Furnaces, Heaters, Fireplaces & Air Conditioning 11 03-12-2006 11:34 AM
A/C shroud painting sovereignrwe Furnaces, Heaters, Fireplaces & Air Conditioning 7 07-29-2005 11:34 AM
Armstrong A/C Shroud Refurb Ideas roadeo Furnaces, Heaters, Fireplaces & Air Conditioning 13 04-16-2005 11:31 PM
