Old 08-25-2010, 09:55 AM   #1
1975 31' Excella 500
Beggs , Oklahoma
Armstrong AC
I just got a vintage 1975 Excell 500... can anyone tell me if the ac had a wall thermostat... got some wires by my heater thermostat and the ac compressor won't kick on... Thanks...
northwind is offline   Reply With Quote
Old 08-25-2010, 10:27 AM   #2
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
Yes, there should be an AC thermostat there.
"Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid." -- Frank Zappa
tlavergne is offline   Reply With Quote
Old 08-25-2010, 10:43 AM   #3
Beggs , Oklahoma
Thanks... That gives us a start... we checked the freon and it seems to be full.. would hate to trash it and it just be a simple fix...
Old 08-25-2010, 11:07 AM   #4
x
XXXX , XXXX
in my 73 excella furnace thermostat is on roadside partiton wall in rear bedroom between bedroom and closet. The air conditioning thermostat is on the roadside partition wall in living room in front of the fridge.
wasagachris is offline   Reply With Quote
Old 08-25-2010, 11:15 AM   #5
Beggs , Oklahoma
anyone know the color code for the stat??? I have a red.. green and brown wire out the wall.. and can see a black one in the wall... and what kind of stat did anyone use to replace theirs would be a great help...
Old 08-25-2010, 12:12 PM   #6
x
XXXX , XXXX
According to manual white goes to teminal marked Y, Black goes to terminal marked G2,Green goes to terminal marked G1 and red goes to terminal marked R. I will check my unit now and see whats what and let you know
Old 08-25-2010, 12:36 PM   #7
x
XXXX , XXXX
Here are pics of thermostat. If you like I can scan wiring diagram and post it for you. Just let me know.
Name:	Air Con Tstat 004.jpg
ID:	109335   Click image for larger version
Name:	Air Con Tstat 005.jpg
Name:	Air Con Tstat 006.jpg
Old 08-25-2010, 03:18 PM   #8
Beggs , Oklahoma
Yes, please.. that would be great...
Old 08-25-2010, 05:20 PM   #9
x
XXXX , XXXX
Sorry for the delay I was working on my excella. Welder arrived today and we began welding together new frame rails. Here is the wiring diagram I promised. Two wires connect to the fan speed control ( High and Low). Two wires connect to the cooling Circuit to start compressor etc. It looks like the green wire at G1 is fan High and the black wire at G2 is fan Low.
Name:	Air Conditioning Wiring Diagram.jpg
Old 08-25-2010, 05:24 PM   #10
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
Thermostat(s)
Mine has 2.
One near the front to control the a/c and/or heater and another a little back to control just the a/c.
It would help you a lot to get a manual or even the workshop type.
I believe they are easily available.
"Talk is cheap, Airstreams are expensive," Wally Byam.
fastrob is offline   Reply With Quote
Old 08-31-2010, 11:54 AM   #11
Beggs , Oklahoma
Can anyone tell me where this black and this white wire hook into the ac, it's a Armstrong 14....
Ellen
Old 08-31-2010, 12:16 PM   #12
Harry W's Avatar
1978 31' Sovereign
Scottsdale , Arizona
Our '78 Sovreign has two 'stats, one for the A/C and one for the furnace. Thee fan control is a knob on the ceiling unit. Just a slightly off topic note, be sure your electric supply is adequate. I almost junked a perfectly good Armstrong unit because of an inadequate extension cord.
Harry W
4CU Charter Member
AIR # 13858, WBCCI # 2420
Harry W is offline   Reply With Quote
armstrong a/c csaweeks Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-12-2009 06:34 AM
Armstrong AC Removed---Now What???? Heirstreamer All Argosy Trailers 6 06-17-2009 01:07 PM
Armstrong AC Rebuild TCHANNEL Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-06-2009 09:42 PM
armstrong a/c mike beech Furnaces, Heaters, Fireplaces & Air Conditioning 16 01-06-2007 05:31 PM
