Old 04-20-2016, 01:21 PM   #1
1967 26' Overlander
Amity , Arkansas
Armstrong AC
my 1967 Armstrong a/c worked great until the blower motor seized (oil). I bought a new motor that was smaller and all 4 bolts were so rusted they broke off. finally found a solution but now the a/c freezes up after a short run. Haven't found anyone in Arkansas so far that will put a new a/c on. I live 35 miles west of hot springs
Johngould is offline   Reply With Quote
Old 05-02-2016, 09:54 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
If the new motor isn't spinning the fan as fast as the old one, your unit will freeze up. It's probably gonna be easier to get the right fan motor.
Old 05-02-2016, 10:34 PM   #3
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
You probably have one of these:
G. E. 26352B14
Marathon 26553B13
Franklin 26351B9
I used my original after having a motor shop check it out. I also visited the local W.W. Grainger branch and they found one that would work. Make sure you get an amp rating as close to the original as possible if you buy a new one.
youngpeck is offline   Reply With Quote
Old 05-02-2016, 10:36 PM   #4
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
pm me if you need a hand. I'm just south of Hot Springs. Clayton
NavyCorpsman is offline   Reply With Quote
Old 05-19-2016, 11:56 AM   #5
1968 24' Tradewind
Butternut , Wisconsin
Sorry about your ac problem. I have an Armstrong Bay Breeze ac but haven't started it up to see if it works. Do you have any brochure or manual for yours? I'm trying to get an owner's manual for mine if there ever was one? Any ideas?
TradeWind222 is offline   Reply With Quote
Old 05-19-2016, 01:22 PM   #6
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
This article was very helpful to me....hope it helps you.
http://www.knology.net/~tcwilliams/AirConditioner.htm
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 05-22-2016, 04:29 PM   #7
1967 26' Overlander
Amity , Arkansas
Smile
Thanks. I oiled the old one up the best I could and right now it is working. all the bolts are rusted nearly off
Old 05-23-2016, 09:30 AM   #8
Regular Guy
1978 31' Sovereign
I am amazed at how well it's built. After I took the covers off and cleaned it up it was even better. Mine had a bit of rust but not too bad. It can get uncomfortably cold, especially in the mornings. What a problem to have. Looking forward to camping out over on Lake Greeson, and Degray State park. The offer stands if you need any help.
Clayton
Old 05-24-2016, 06:11 AM   #9
1967 26' Overlander
Amity , Arkansas
Ac
Thanks for the offer. I will try it out soon and see what happens
armstrong a/c mike beech Furnaces, Heaters, Fireplaces & Air Conditioning 16 01-06-2007 06:31 PM
True story:NEIL ARMSTRONG 53flyingcloud Off Topic Forum 7 11-28-2002 05:50 AM
Missing piece for Armstrong A/C? 74Tradewind Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-10-2002 05:16 PM
Armstrong drain lines davidz71 Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-03-2002 10:01 AM
Armstrong A/C Woes on 71Sovereign MikeT Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-14-2002 01:09 PM
