Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 06-14-2002, 12:08 AM   #1
MikeT
Profile:
Question Armstrong A/C Woes on 71Sovereign
Original Armsrtong A/C unit was "serviced" with freon summer of 2001 and did well till fall. This year, after about 1 month, compressor would come on intermittently and then finally quit. Discovered bad start capacitor and starter relay. Replaced both. Started unit and ran fine for several minutes then compressor began cylcling on and off. I would appreciate any an all suggestions (just short of ditching old unit, unless there is no hope). MikeT
MikeT is offline   Reply With Quote
Old 06-14-2002, 01:09 PM   #2
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Mike T,
Andy from Inland RV posted a response to you question on another forum that it might be a fan condenser. Don't give up on the Armstrong yet. Craig
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
armstrong a/c mike beech Furnaces, Heaters, Fireplaces & Air Conditioning 16 01-06-2007 06:31 PM
Is A/C original? whistler Furnaces, Heaters, Fireplaces & Air Conditioning 2 01-19-2004 05:32 AM
34' Excella 1000 needs cooler A/C cjholloway Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-17-2003 07:50 PM
A/C blowing the breaker Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 13 07-08-2003 11:52 AM
Missing piece for Armstrong A/C? 74Tradewind Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-10-2002 05:16 PM
test
