Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 01-20-2009, 11:13 PM   #1
Mini Rivet
Profile:  1975 25' Tradewind
Holland , Michigan
Armstrong A/C, roof caving in
Took the center ceiling panel out today and noticed the roof is bowing in under the A/C unit, Armstrong TR21-12.
I also noticed that all the supports running between the ribs are one piece except under the A/C unit there two pieces.
Surprisingly this does not leak.
Been reading previous post on the subject and just want to make sure I get the repair right.
1, Are sheet metal screw into the exterior skin the only thing holding this down?
2, Is there a gasket under the unit or caulk or both?
3, How do I seal it when I put it back on? I've read Andy at Inland say Airstream used Vulkem, others have said there was a gasket.
4, Olympic rivets or screws again when reattaching?
5, How should I reinforce the ceiling? I'm thinking a 1/4" aluminum angle running front to back between ribs
6, Do I need additional support side to side?
7, What should I do or have done to the A/C unit while it's off?
8, What other questions should I be asking and/or what else should I be doing?
Thanks for the help
Name:	AC Curb side.jpg
ID:	74298   Click image for larger version
Name:	AC Street side.jpg
Name:	AC Front.jpg
ID:	74300   Click image for larger version
Bruce,
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working.
Parts needed: Left Wing Window Dual Pane, Fan for roof vent or whole vent fan assembly, Reese old style dual cam sway control, one 30# aluminum propane tank, vented catalytic heater
bmklawt is offline   Reply With Quote
Old 01-20-2009, 11:24 PM   #2
goransons's Avatar
Profile:  1969 25' Tradewind
1963 22' Safari
State of , Washington
Airstream Registry
Send a message via MSN to goransons
you can buy aluminum extruded C channel at most any metal supply shop that can be used to fill this space and provide support for the interior and exterior skin. I don't know specifically about your model AC, but I know that others I have worked on don't screw to the trailer, but instead are bolted through to the inner control unit with long bolts through the 14x14 opening, sandwiching the gasket against the trailer. Granted I haven't worked on to many air conditioner units, so can't claim to have seen it all.
Scott & Megan
WBCCI #8671 Oregon Unit
Visit our Blog- http://safari8671.blogspot.com
63 PARTS NEEDED
bathroom heat register cover
63 refer, or at least the original door insert
2 12v hehr motors (working) w/ or w/o fan blade
fan switch covers (city-off-battery)
goransons is offline   Reply With Quote
Old 01-21-2009, 12:54 AM   #3
Silverwanabe's Avatar
Profile:  1967 26' Overlander
Winston Salem , North Carolina
Images: 101
Airstream Registry
I thought all the Armstrong AC's were riveted to the outer skin , not screwed in ?
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
Website: http://piedmontunit.wbcci.net/ welcome/
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 01-21-2009, 08:54 AM   #4
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
Airstream Registry
You are on the right track with installing a froward to aft additional stringer. However, .250 is a little overkill. If you can find "C" channel the outside dimension is 1.750. If angle is used .125 will work, if "C" is used then .0625 will be fine. Be sure to tie the ends to the frames with a clip
Old 01-21-2009, 02:25 PM   #5
TomW's Avatar
Huntsville , Alabama
I used to think that until I worked on mine
My Overlander's outer unit is screwed on with "RV putty" originally sealing the interface. The inside unit is riveted.
Tom
Old 02-04-2009, 06:53 PM   #6
Mini Rivet
Holland , Michigan
Rivets and Gasket
When I add supports either angle or channel between the ribs, do I need to rivet the skin to the support.
Would there be enough movement between the skin and new stringer to wear through the skin if not riveted.
Also do I need a gasket or will Vulkem do.
Bruce,
Roof repair advice - hole in roof 1956 vintage casaalumina Roof 5 10-05-2008 11:24 PM
Roof flange solutions for 14" x 26" Astrodome roof vent. Petethefeet Roof Vents, Skylights & Fans 46 05-01-2008 12:13 AM
Cleaning debris from roof? White roof? maxandgeorgia Cleaning, Stripping & Polishing 1 06-05-2004 10:59 PM
Armstrong AC available smily Parts Archive 0 07-26-2003 08:39 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
