Old 10-01-2010, 07:39 PM   #1
lahrfarm's Avatar
1985 31' Excella
Crescent , Oklahoma
armstrong A/C
My original A/C cools great, but may have a problem. When the compressor turns off after cabin reaches set temp. the fan continues to run, it never turns off, the compressor cycles like it should. I assume the fan should cycle as well, like the new ones do? I replaced both fan relays to get it to work in the begining. I know they are wired correctly according to schematic. the fan motor was replaced by PO and has extra wires so it could be the issue. I just wanted to make sure there is an issue before I work on it more
lahrfarm is offline   Reply With Quote
Old 10-01-2010, 08:00 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Cut off relay?
Does the schematic show a cut of relay for the fan motor? If not it probably is intended to run as long as you have the unit on.
Old 10-01-2010, 08:13 PM   #3
lahrfarm's Avatar
1985 31' Excella
Crescent , Oklahoma
The only relays are Hi fan and Low fan
Old 10-01-2010, 10:17 PM   #4
Your AC operation, is perfect.
The fan always runs, even when the compressor cycles, as long as you have the AC turned on.
You may have other issues with the trailer, but certainly not with the AC.
Armstrong AC northwind Furnaces, Heaters, Fireplaces & Air Conditioning 11 08-31-2010 12:16 PM
armstrong a/c csaweeks Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-12-2009 06:34 AM
Armstrong A/C Removal Alumanutz Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-20-2008 07:52 AM
armstrong a/c mike beech Furnaces, Heaters, Fireplaces & Air Conditioning 16 01-06-2007 05:31 PM
