I would get a "thru the wall"....not to be confused with a window or wall air conditioner... thru the wall types use a sleeve and air in and exhaust both go thru a single louvered door or panel. You can mount this in an existing compartment, appropriate size and location for the air to the inside. Mount it on a slight incline so the drip pan takes the condensate where you want it.....you don't want a puddle on the awning side. With this sleeved type you don't have to build a plenum for air management. I think you could even mount the ac on a heavy duty slide which would extend completely when used....I don't care for this one...but it works.
