Old 10-29-2008, 08:01 AM   #29
HowieE's Avatar
Princeton , New Jersey
Images: 12
I have a Wave #3 just to heat the living room area while watching tv. It is 4 years old and has lost about 1/2 it's capacity. Olympic says the element has gone south because I never covered it when not in use. When originally installed I had not heard that they should be covered.
Has anyone come up with an idea to reclaim the element short of sending back for replacement?
2004 Excursion 4x4
Old 10-29-2008, 08:30 AM   #30
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question Clue me in please..
We were just in the Adirondacks 2 weeks ago, hard frost each night. 30-40 degrees. Used the furnace at least 4 nights straight set @ 65.In the morning, 12.5 in the 4 year old interstates. Other than the covering on the interior walls is there any other reason why the classic seems to stay warmer with less furnace? Set at at 65 the furnace cycles about twice every 1/2 hr for about 5-8 min. We have a 30w solar that usually brings the batts back to 12.8-.9 on a sunny fall day. Has any-one actually Fluked the fan while on, what was the draw?
The whoosh-whoosh from the outlets has never been a problem. So I guess we just be lucky.
PFC
"Tahawus"
RLC
Step aside Starbucks, this is a job for alcohol.
Old 10-29-2008, 08:41 PM   #31
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
I'd say you are doing pretty good with those numbers! We haven't actually tested to see what the furnace blower draw is...but I'd be curious. Part of it might also depend on how humid it is as to how well the heat is retained. We like to sleep cool so we have plenty of cozy bedding, but that darn floor gets awfully cold! Nice to have it warmed up a bit in the AM when we crawl out.
TB & Greg and Abbey Schnauzer
#3954
Old 10-29-2008, 10:44 PM   #32
pauly g's Avatar
1960 22' Safari
Oceanside , California
My wave 6 works well, but tends to shut itself off while running on the low setting for some reason. Otherwise, I am satisfied with the heater.
pauly g is offline   Reply With Quote
Auxiliary catalytic heater bhsl8 Furnaces, Heaters, Fireplaces & Air Conditioning 30 07-16-2006 03:41 PM
Catalytic Heater eracism Furnaces, Heaters, Fireplaces & Air Conditioning 1 01-06-2003 07:15 PM
Catalytic Heaters - Who Wins? Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 8 11-18-2002 07:09 AM
Another Catalytic heater question Ken J Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-26-2002 10:57 AM
Olympian Catalytic Heater davidz71 Furnaces, Heaters, Fireplaces & Air Conditioning 0 03-26-2002 10:47 AM
