Old 06-21-2010, 08:08 AM   #1
Marianne
mspeas's Avatar
1960 18' Traveler
Welaka , Florida
Anyone using a split AC system?
We wondered if anyone has used the split AC units available? Marianne
Marianne one proud owner of the "Dottie M"
mspeas is offline   Reply With Quote
Old 06-21-2010, 08:20 AM   #2
JVW
JVW's Avatar
1989 34.5' Airstream 345
BRANDON , Mississippi
I have a 1989 345le motorhome. I took the a/c power cord that goes from the generator to the rear ac , and installed a a/c connector (both male and female connectors ) that way you can unplug the connector and plug in a/c shore power. I run both the front and rear ac units at the same. Hope this answers your question.
JVW is offline   Reply With Quote
Old 06-21-2010, 09:13 AM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
The Danhard systems used in ambulances are the only split systems I've heard of that might be applicable to an Airstream. They are, essentially, an automotive A/C system with a 120 volt compressor. I believe some of them are set up with two compressors so they can be driven either by the engine or by shore power.
Old 06-21-2010, 09:20 AM   #4
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Do you have a name and model? I have only seen split units for houses being able to use wall space instead of window for cooling unit, they use 120 or 240 AC.
Old 06-21-2010, 10:48 AM   #5
87MH's Avatar
1978 31' Sovereign
Images: 292
Marianne:
You may find this thread interesting:
http://www.airforums.com/forums/f427...ips-42657.html
Also, the 9 1/2" tall Dometic (Duo-Therm/Penguin) topmount AC is a minimal intrusion to the roofline of your Airstream. It only sticks out about 6" forward of the vent, and about 22" towards the rear.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 06-21-2010, 10:53 AM   #6
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Check out SmokelessJoe's work on his Argosy, starting at post 110 for the split AC stuff. It picks back up with the inside part of the unit at post 154.
In reality, you want to check out this entire thread. The work and ideas are outstanding!
Vaughan
air conditioning
split rim or not??? G1obetrotter Wheels, Hubs & Bearings 11 05-09-2010 12:06 PM
Split System A/C advice needed 65CV Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-10-2007 04:11 PM
What does a split rim look like? tbrom Wheels, Hubs & Bearings 9 09-30-2006 04:58 PM
Split Rims Julison Wheels, Hubs & Bearings 5 10-12-2005 08:49 PM
Split Rim Or Not? Jabba Wheels, Hubs & Bearings 3 11-11-2002 07:43 AM
