Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 11-24-2003, 07:17 PM   #1
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
Question anyone ever balance the airflow on a furnace?
wondering if anyone has ever diverted more air to the rear of a coach from the furnace?
here is the deal, during this last weekend deer hunting and staying in my trailer it was cold outside, with a low of 13 this morning.
my furnace is under the range, the furthermost forward cabinet. the living room duct is about 3 inches long, the rear bedroom duct is approx 15 feet long. therefore almost all of the heat goes to the living room.
has anyone tried to partially block the shortest duct to make the trailer heat more even? if you did what did you use.
being born and raised in a cold climate i don't mind the bedroom being cooler, in fact i like it!
what i would like is the bathroom being a bit warmer.
any thoughts or ideas?
john
you call them ferrets, i call them weasels.
Old 11-24-2003, 07:38 PM   #2
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
John, mine has a louvered register in the front and back. The louvers are adjustable. I suppose you could duct tape a piece of cardboard over all or part of the front register, if yours are not adjustable.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 11-24-2003, 07:41 PM   #3
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
John,
on my unit you can open and close the vents, well you could if they weren't rusted half open. But anyway take a look at the front one and see if you can close it off, other wise there is always duct tape BTW we use a small electric heater in the bath to warm it up before we go in...can't stand a cold throne, reminds me too much of the days before indoor plumbing in Iowa, in the dead of winter!
Aaron
wahoonc is online now   Reply With Quote
Old 11-24-2003, 07:46 PM   #4
john hd
john hd's Avatar
madison , Wisconsin
Images: 40
pick/aaron
mine just has 4" plastic round vents that you can swivel to direct the flow, not shut it off.
the duct tape idea is sounding better!
wonder if i could find the same size vent with a closeable louver?
john
Old 11-24-2003, 07:56 PM   #5
wahoonc
Rivet Monster
wahoonc's Avatar
1980 31' Excella II
Images: 35
John
try this link, look at the one on the top right corner of the page
http://www.go-rv.com/coast/do/catalo...22&pageNum=252
I just figured AS was still using those good old steel one, another thought comes to mind, maybe you could install a booster fan part way down the duct to force the air to the bath room vent?
Aaron
Old 11-24-2003, 08:10 PM   #6
garry
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
Fan in bath duct
John the AC people tell me fast fan for AC, slow fan for heat. You could put in a small 24VDC fan inside rear duct at bath. Would run at half speed and no noise.
My vents are adj but still the air in rear is not what it could be.
Garry
Old 11-24-2003, 08:24 PM   #7
john hd
john hd's Avatar
madison , Wisconsin
Images: 40
aaron
that looks just like what i need!
thanxs for the link.
i remember reading in the suburban manual that one should not use booster fans. perhaps they could inadvertently trip the sail switch turning the gas on.
john
Old 11-24-2003, 09:18 PM   #8
norbert
norbert's Avatar
Profile:  1993 30' Excella
chicagoland , state of confusion+north of cheddar curtain
Images: 24
john...
my rig is one year younger then yours..im surprised if you dont have adjustable supply louvers....the ductwork layout sux the big green one...i was able to pinch the bathroom which was hotter then a horse pistol...but sadly because of the horsesh*t layout...i couldnt force anymore back into the bedroom due to the small diameter duct run..... we both either have to change the duct diameter...or change where we crash and snore...
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 11-24-2003, 09:35 PM   #9
j54mark
Profile:
I am a bit surprised that you don't have enough heat for the bathroom - it is such a small space, yet is served by the same size duct as the other areas. We have a somewhat weak airflow to the back bedroom - and ours is just a 25'. Like you, though, I like to sleep cool, so have not tried to address it.
I suspect the problem is a combination of the flexible ductwork and the convoluted path to the bath, going under the floor and back up. I also would not be surprised if you have serious kink in that duct, restricting the airflow. It would be worth looking for. Of course, if it is under the floor it would be a bear to fix.
I have thought about getting straight metal ducts for the two flex ducts that run from the furnace across the kitchen and wardrobe cabinets to increase the airflow. Just one of those things on the to-do list.
Mark
Old 11-24-2003, 09:54 PM   #10
john hd
john hd's Avatar
madison , Wisconsin
Images: 40
mark
you are correct about the duct layout.
it just seems like it was tossed under the cabinets. runs here and there. straightening it out is a good idea.
norby,
can't think of crashin anywhere else, i sleep better in the a.s. than i do at home!
john
Old 11-24-2003, 09:57 PM   #11
norbert
norbert's Avatar
Images: 24
well gosh....
of course in meant the front as opposed to the back....
Old 11-24-2003, 11:00 PM   #12
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
The other issue is that the tank heat is normally fed off the ducts that run to the rear of the trailer. This means that 1/2 the heat that is going toward the rear never gets there, it heats the tanks.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 11-24-2003, 11:45 PM   #13
j54mark
Profile:
"The other issue is that the tank heat is normally fed off the ducts that run to the rear of the trailer. This means that 1/2 the heat that is going toward the rear never gets there, it heats the tanks."
That is true, and now I think of it, it is the bathroom duct that feeds the fresh water tank. The holding tanks are, of course, heated through the bottom of the furnace.
Mark
Old 11-25-2003, 06:49 AM   #14
Mariner
Mariner's Avatar
Profile:
Hi all,
Have just read the above thread with interest. The furnace fan motor is a DC motor. Can dc motors slow down due to brush wear? Just a thought. maybe the fan intake is partly restricted with dust buildup or slowed down due to the dirt build up.
My thought would be to remove the fan motor - if possible and clean and replace the motor brushes. Can't do any harm and it might just make it work better.
Mariner
Mariner
1987 Avion 34V travel trailer (the other cigar tube).
2002 Dodge CTD 3500 Dually, Auto, 4x4
1986 F250 T/C 6.9 Diesel, LB,S/C,4x4,Auto
Mariner is offline   Reply With Quote
test
