Old 11-12-2015, 11:49 AM   #29
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
So far no issues with vibration. I had a cover made for the outdoor unit to protect it while towing. Kill-A-Watt shows max draw of 8 amps. Pretty sure that means I can run the entire trailer on a single Honda 2000 gennie since the fridge and water heater can both run on LP. 12,000 BTU seems like plenty for this trailer. I am completing my birch paneling of the interior which should improve insulation somewhat. Highly recommend this unit if you are willing to do the work to install it.
BambiTex is offline   Reply With Quote
Old 03-26-2017, 09:26 AM   #30
1959 24' Tradewind
Twin Falls , Idaho
I recently came across doing this on a Boler and looked more and found this thread. been thinking about doing this instead of the rooftop AC for the same reasons you had. Great work. How has it held up so far? Was there a reason you didn't install it on the back bumper (if you have one)? Was it the length of tubing that came with the unit? Oh, and how did you wire it up electrically? Thanks
Regards,
Tony
Trons4u is offline   Reply With Quote
Old 03-27-2017, 10:43 AM   #31
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Answers
1. Held up great for two years. Recently sold the trailer and new owners love it. Just got another unit for my next trailer.
2. Weight in the rear is generally a no-no, rear bumper too small anyway, and wanted to mount indoor unit in the front.
3. Line set length can be specified when you order. I got the minimum (10 feet) and cut it to length.
4. Although they recommend hard wiring, I spliced a plug on the end since:
a) I had a convenient outlet close by, and
b) It gives me the option to plug it into a separate power source.
Old 03-27-2017, 11:13 AM   #32
Boxite's Avatar
2008 22' Sport
I've seen BambiTex's unit in operation and it's very quiet and cool (pun) indeed!
The only question I failed to ask is: Since it is mounted fore/aft, it appears to obstruct a tight left-hand turn (reduced clearance between AC unit and TV rear bumper)... especially vulnerable when backing-up. Why did you choose that orientation over a lateral one? Would your single LP tank not fit in front of a lateral install?
George
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 03-28-2017, 10:11 AM   #33
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
BambiTex
Very nice work on your first install. So, what changes will you make for your second installation?
Thanks, Dan
Old 03-30-2017, 03:36 PM   #34
1959 24' Tradewind
Twin Falls , Idaho
Great too hear, thanks for the response. I like the idea of a split system. May look into extending the tongue about 12" so I can keep the propane tanks. It's waiting to be sandblasted right now. Hmm, decisions.
Regards,
Tony
Old 03-31-2017, 11:31 AM   #35
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Answers
1. Yes, orientation does affect tight left hand turns. I have a dent in my bumper cover to prove it. Switching to a longer ball mount solved the problem.
2. There was not sufficient room for the compressor, LP tank and tongue jack if oriented transversely.
3. Tongue on my Overlander is slightly longer, and I added an electric tongue jack which increases clearance as well. New install will be traverse. I plan to move the LP bottles back against the trailer body and mount the compressor in front. It is a shame, since the shiny LP bottles will be blocked but airflow would be compromised otherwise.
Old 04-05-2017, 07:27 AM   #36
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
New install in progress
Built a platform and moved the LP bottles as close as I dared to the trailer body, bolted aluminum angles to tongue. Compressor will bolt to angles through rubber vibration mounts. Pretty tight fit and not ideal in terms of airflow but the tradeoff is a nice compact footprint.
Name:	Compressor mountR.jpg
ID:	282742   Click image for larger version
Name:	Compressor side viewR.jpg
Name:	AC front viewR.jpg
Old 04-05-2017, 08:31 AM   #37
Boxite's Avatar
2008 22' Sport
You're gonna hate me for saying this.... but I mean it in the best way.... I'd have mounted the AC unit close to the trailer and considered going to one LP bottle. The warm air from the AC would facilitate vaporization of LP, and the round bottle would be very little obstruction to the air flow, and the AC unit would be better protected from road debris. The turning radius would also be improved, and the pretty aluminum bottle would be better admired.
Rambox
Old 04-05-2017, 10:34 AM   #38
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Smokeless Joe visited with us in Georgia on his around the US tour. He had an incredible and enviable rig. The ductless air unit was beautifully done and worked great.
He also had diesel powered hot water and stove as I recall. Sold the whole rig to a couple off the forum.
I use the method I got from a guy here, mounting a window unit in the front of my trailer with a small wooden folding leg table support on the window frame and the propane bottles. Smaller ac unit works quite well up into the low 90s but can't beat back the heat and the Sun when its any hotter.
Thank fully we mostly used it at night where it did the job.
Issue with is is the placement,as the cold air made the gaucho not the best place to sit. Have to say I paid $35 used for it several years ago and it has been pretty good to this point. But I am open to a better idea.
Just found a photo of Joe and his rig:
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 04-06-2017, 06:54 AM   #39
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Not workable
That would have put the intake side of the unit right up against the trailer body. They say you need at least 12 inches clearance, which I have (though the LP bottles are a partial obstruction). Believe me, I considered all possible placement options before settling on this one.
Old 04-06-2017, 06:59 AM   #40
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Many options
I used a 6000 BTU window unit in my first AS (17 ft Bambi II) mounted in the rear window on a cantilevered "table" platform and it worked great. For a 26 footer I need more BTU's and window units that size are too big and heavy to install/remove while travelling. Putting one in the front window is not ideal from an airflow and aesthetics standpoint IMO but to each his (or her) own....
New A/C ran for 5 min - dead? adwriter73 Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-18-2011 07:44 PM
My 15 min.of fame with Jimmy Buffett WHO DAT! fotochop Off Topic Forum 14 01-31-2010 08:08 AM
First real trip; real dumb mistake... myoung On The Road... 49 03-29-2006 07:37 PM
Rocky Mtn 15 min of fame yukionna Our Community 3 08-12-2005 06:29 PM
what size tires? please respond within 22 hours and 46 min..... Whistling_Gypsy Tires 5 01-07-2004 04:31 PM
