Old 09-10-2015, 07:24 AM   #15
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Roof units
Originally Posted by Wayward View Post
I've seen others mention this and am curious. Is the the roof structure inadequate for the weight on older models? Or is it aesthetics?
I've seen AC added to classic cars with good results but on a travel trailer... boxes always seem to end up sticking out of somewhere.
I have three main objections to roof units:
1. Totally ruins aerodynamics and aesthetics, particularly on a vintage trailer.
2. They are loud.
3. In my case, it would make the trailer too tall to store in my garage.
BambiTex is offline   Reply With Quote
Old 09-10-2015, 07:26 AM   #16
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Not adequate
Originally Posted by Foiled Again View Post
We have two of these in our office to keep our servers cool.
Portable AC Units : Portable Air Conditioners - Walmart.com
They have an exhaust hose like an oversized dryer vent hose - that I'd bet would fit perfectly in the shower vent fan opening.
Of course moving the dratted thing in and out of the shower would be a PITA. But during the spring and fall you could leave it home. On the plus side, no holes in the aluminum. And they're not expensive.
Paula
My current AC is the Honeywell unit shown in your link. It has proven totally inadequate to combat the Texas heat, even when mounted high in a closet and vented through the refrigerator roof vent.
Old 09-10-2015, 07:28 AM   #17
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Not enough BTUs
I saw this at a local RV show: It is a portable type that can mount on the tongue with no interior unit. Can be removed when not needed.However max BTU is 5000.
ClimateRight 5000 btu A/C & Heater
video install
Old 09-10-2015, 07:30 AM   #18
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Not quite correct
Originally Posted by idroba View Post
The problem with residential mini split AC units units used in an RV is that they are big. The exterior unit is relatively large and about the only place to locate it is on the tongue where it competes with the gas bottles, and the batteries and the hitch parts. The interior unit is also relatively big and designed for vertical wall installation with pipes coming out the back of it. There is not a lot of space inside an AS that can be used in that way. Sure, complete custom interior with the interior part of the mini split designed in could be done, but it is not an easy task.
Most residential mini splits operate on 240 volts, and there are a very limited number which run on 120 volts, the standard RV voltage system. The only 120 volt units I have seen peak out at 12,000 btuh. Often they are not inverter technology compressors, but the more conventional type, which makes them somewhat less desirable.
I can see some great possibilities for better RV AC units but no one is building them at this time. Adapting home ductless mini split units is difficult and questionable. Sure, it can be done, but it is custom work, and very far from plug and play.
The one duct "portable" units are very very inefficient in that they suck hot outside air into the RV to cool the unit and blow the hotter air outside. The two duct portable units, if you can find space for them and the dual input and output ducts make some sense, but again are not easy to fit into the interior of an Airstream.
Unfortunately there is no really good alternative AC systems for RV's, especially curved wall Airstreams.
The split system I installed is 12,000 BTU and 120 volt (only draws 8 amps max and is indeed an "inverter" type).
I will agree that installation is a PITA and far from plug and play. I am hoping the effort yields the desired result. Will keep y'all posted.
Old 09-10-2015, 07:31 AM   #19
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Agree completely
Originally Posted by streamachine View Post
idroba go back and look again I have been researching these for a little while and there are plenty of units out there that run on 110. most of the manufacturers that produce these mini split units offer 110 units with as high as 21000 btu. yes it can be a problem getting the outside unit and propane bottles on the tongue but personally i would rather carry my propane bottles in the back of the truck as to see those ugly monstrosity A/C units stuck on top of a vintage airstream. They just completly screw up the sleek lines of the airstreams even the new ones.
My sentiments exactly!
Old 09-10-2015, 10:07 AM   #20
Cardinal283's Avatar
Dallas , Texas
How many BTU was your old Honeywell unit? The one you said wasn't big enough.
Cardinal283 is offline   Reply With Quote
Old 09-10-2015, 10:13 AM   #21
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
Take a look at Dometic all in ones.
jkcru is offline   Reply With Quote
Old 09-10-2015, 03:27 PM   #22
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
8000 btu
It is the biggest unit I could fit in the closet. Nowhere near adequate, and the vent hose throws off lots of heat, even after adding insulation.
Old 09-10-2015, 10:23 PM   #23
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
We have a split system in a church office. It has been great! The lines are flexible enough that you should not have much of an issue.
When installing my AC DEAUX(#2), rather than pull down inner skins, I did a ceiling penetration, ran power and condensate lines along inside of ceiling, concealing with an expanding "loom", not the plastic looking one, a nice black weave. My wife was going to make a fabric cover for it, but it turned out so nice, we left it plain.
I "penetrated" the shell at the floor, coming out in the water access box! The condensate tube lines up with the opening for the fresh water hose entry!!!! Slick.
For your front mount, I would come from underneath, like the turn signal umbilical enters the newer models. This would keep it water safe and allow you to run your connections up inside the trailer. You can easily camouflage them with thin wood or aluminum....
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-18-2015, 06:59 AM   #24
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
With help from a friend, I got the refrigerant lines vacuumed and leak free, then released the refrigerant to charge the system. Ran it for 30 minute test on both heat and cool modes. The outside unit is very quiet and the inside unit is barely audible. Max current draw is 6 amps due to "inverter" style compressor. Real world testing still required to see how it handles vibration while towing and whether it can handle the Texas heat but so far I am very impressed with this $700 unit.
Old 09-18-2015, 10:41 AM   #25
2012 30' Classic
Homosassa , Florida
I have a mini split in my garage. It does noticeably well in the heat considering the garage is uninsulated.
Tater is offline   Reply With Quote
Old 09-18-2015, 11:02 AM   #26
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Just returned from vacation in Aruba. Virtually every building on the island has units like this. Probably saw over 1000 split systems compared with about 6 conventional window units and perhaps 10 full-fledged forced air central A/C units.
Old 09-20-2015, 11:42 PM   #27
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
I applaud your efforts. Along with the Texas heat and your desire to park your vintage Airstream in the garage this is your only option. Great job. Motivation and persistance is the key to your success.
My window AC unit in our 66 Tradewind works fine for us and was really pretty simple.
Dan
Old 10-12-2015, 08:19 AM   #28
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Initial use report:
Just returned from a 10 day trip to ABQ Balloon Festival and Grand Canyon NP. Ran A/C lightly during the day and heat pump all night. Almost whisper quiet. Performed beautifully. Coldest night was 38F and trailer was a toasty 72 inside.
New A/C ran for 5 min - dead? adwriter73 Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-18-2011 08:44 PM
My 15 min.of fame with Jimmy Buffett WHO DAT! fotochop Off Topic Forum 14 01-31-2010 09:08 AM
First real trip; real dumb mistake... myoung On The Road... 49 03-29-2006 08:37 PM
Rocky Mtn 15 min of fame yukionna Our Community 3 08-12-2005 07:29 PM
what size tires? please respond within 22 hours and 46 min..... Whistling_Gypsy Tires 5 01-07-2004 05:31 PM
