Old 04-05-2009, 11:45 PM   #1
ronstory's Avatar
1975 23' Safari
Portland , Oregon
Any one tried a Coleman Mach 3 P.S. (Power saver)
All--
Been off the forums for the last two months trying to buy a new home for the Airstream... and hopefully it will let us live with it as well.
I have an original Armstrong and want to get a more modern unit. Almost all of the 13.5K BTU use 15-17A of AC. I was just googling and found this unit... RV Protection Products:Coleman Air Conditioners.
It is suposed to use less power at only 10.2A but offer the same cooling, which seem too good to be true. It's looks to be new and available at several poplular RV supply sites.
Anyone else seen this or bought one? I tried looking for the factory Coleman-Mach website for a manual but no luck.
Ron
ronstory is offline   Reply With Quote
Old 04-06-2009, 12:50 AM   #2
Originally Posted by ronstory View Post
All--
You will need a drain pan with that unit.
Unfortunately, none exist.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 04-06-2009, 09:15 AM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
I seem to recall someone saying they were able to get a plastic drain pan through this company. Might be worth the phone call if you really want that unit and don't want water running down the side of your Airstream when it's in use....
Thomas & Son RV Supply
Old 04-06-2009, 02:01 PM   #4
ronstory's Avatar
1975 23' Safari
Portland , Oregon
Andy/Gary--
Thanks...
Ron
Old 04-06-2009, 02:07 PM   #5
ronstory's Avatar
1975 23' Safari
Portland , Oregon
Andy/Gary--
I was too quick on the return... I was trying to find a schematic of the Coleman-Mach 3 PS, but no real luck. I did discover the website for Coleman-Mach is www.rvcomfort.com
The product blurb is:
http://www.rvcomfort.com/pdf_documents/mach_3_ps.pdf
and some of the specs are:
http://www.rvcomfort.com/pdf_documen...data_copy3.pdf
I don't like the idea of water running down the side and it's almost as tall as the old Armstrong... but only need one Honda UE2000i would be nice to run the AC. I would not find the water drain holes on the specs to see what a pan would need to look like.
Ron
Coleman Mach III gasket bkahler Furnaces, Heaters, Fireplaces & Air Conditioning 16 05-16-2021 12:04 PM
Generator Size for 13,500BTU Coleman Mach 3??? dscluchfc Generators & Solar Power 26 07-28-2010 06:07 PM
Coleman TSR Mach 3 Drain tube bertro Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-07-2008 10:57 AM
Airstream Screen Saver jcanavera Off Topic Forum 24 09-25-2006 11:05 AM
Water Saver for Shower jaco Fresh Water Systems 14 04-25-2004 09:09 PM
