Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 04-03-2007, 07:00 PM   #1
dnrtheil
dnrtheil's Avatar
Profile:  1964 24' Tradewind
Portage , Michigan
Question Any known furnace problems
Has anyone ever heard of furnace problems with the International furnace in the '64 Trade Wind? The PO told us the furnace has never been fired on account of the "danger". He had heard it was dangerous to light the furnace.
We'd like to try out the furnace this weekend, but are a bit leary after hearing his comment.
Any advice appreciated.....
Thanks!
dnrtheil is offline   Reply With Quote
Old 04-03-2007, 07:09 PM   #2
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Whether intuition on his part, or a known problem, I would have it serviced/checked by a qualified tech.
Dave
Fyrzowt is offline   Reply With Quote
Old 04-03-2007, 07:20 PM   #3
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
I wouldn't light a unit that has been sitting for a year or more, or even THINK about it on a unit like yours that has not been ignited for years! Mine will be just a year when I hit the road in June, but I will be doing a total clean and adjust before I leave, as I do with all of the LP components. Throw in an air conditioner coil cleaning, water tank sanitizing and a few other chores and the 19CCD will be ready to hit the road.
Find a 'qualified' repair shop or mobile RV tech and have the unit cleaned and bench tested for proper operation.
You never know who or what may have taken up residence with-in. .
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 04-03-2007, 07:33 PM   #4
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 104
Greetings dnrtheil!
Thanks!
The International Oil Furnace was the first appliance to be replaced in my Overlander. The long-time Airstream dealer who has done all of my systems repairs and maintenance suggested replacement as I would have 1/2 to 2/3 the cost of a new furnace into the inspection and cleaning of the old furnace and would still have a 35-year old furnace (this was several years ago) for which parts are (were) no longer available. I have no regrets about going with a new furnace -- the new furnace is quieter and has automatic ignition -- no more doing headstands to light the pilot (a task that I never enjoyed) -- and takes up far less space in the cabinet under the range. I know that my reason for taking the coach in for inspection eight years ago was the reuptation of the particular model of the furnace in my Overlander for developing carbon monoxide leaks from difficult to identify pin-holes in the heat exchagner.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
overlander64 is online now   Reply With Quote
Old 04-03-2007, 07:41 PM   #5
markdoane
Profile:  , Minnesota
Images: 59
I replaced mine.
Although it looked pristine, when I turned it over and shook it, about 5 lbs of rust fell out.
Non-contributing deadbeat.
Old 04-06-2007, 11:22 AM   #6
dnrtheil
dnrtheil's Avatar
Portage , Michigan
Thanks you all for the information. I'll make sure to pull the furnace for a closer inspection once I have the trailer in my possession. Going to pick it up tomorrow (4-7-07)
Derek
72 Airstream International Furnace parts loechli Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-20-2008 07:17 PM
Furnace stuff... Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-02-2002 05:36 PM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 09:59 PM
Forced Air furnace Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 16 11-02-2002 09:41 PM
Furnace problems... Andy R Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-01-2002 08:29 PM
