Old 07-11-2010, 04:13 PM   #1
2007 25' International CCD FB
San Antonio , Texas
amps required to run Dometic A/C
I know this question has been asked and answered before, but can I run my Dometic Penguin A/C (13500 btu) on a standard 15 amp circuit. I am thinking that I can turn the fridge to propane, and turn off the battery charger during the hot hours.
We are traveling and will be visiting freinds, and our two little dogs will need to stay inside, but that is not possible without A/C.
Barry
Barry Parkof is offline   Reply With Quote
Old 07-11-2010, 04:42 PM   #2
Dan@LED4RV's Avatar
Denton , North Carolina
Barry,
It is not advisable but some people do it. You will notice the end of your shore cord will be getting warm. It is also hard on the AC fan motor.
I strongly worn that if you go off and leave your dogs there and the breaker trips with no cool air it could be very bad for your little ones.
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 07-11-2010, 05:03 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
A 15 amp circuit is wire with #14 wire that is rated at, Yes 15 amp but the breaker should trip at about 12 amps. This is to protect the wiring.
If the AC starts and the breaker holds for any length of time you will most likely have a fire in the house wiring as the wiring will heat up.
Another consideration when pulling 15 plus amps through a wire not rated for it will be a drop the voltage. Depending on the length of wire from the panel to the AC you could drop the voltage enough to kill the compressor in the AC. the compressor will be damage at voltages below 105 volts. Over heating.
In other words you are not only operating outside the code but it is just a dumb idea unless the insurance is paid on the house.
2004 Excursion 4x4
Old 07-11-2010, 05:28 PM   #4
Central , Mississippi
Originally Posted by Barry Parkof View Post
I know this question has been asked and answered before, but can I run my Dometic Penguin A/C (13500 btu) on a standard 15 amp circuit. ...
Barry
It's going to depend on the actual model of the AC unit...
According to the specs from Dometic, the fan typically pulls 3 amps...
Some models of the 13.5 K BTU compressor pull as low as 10.3 amps...model 520315.501 for instance
If a 15 A plug won't handle 13.3 amps sumthin' is goofy...
BTW...I run my 11 K BTU AC off of a 15 amp cord...it pulls 12.6 amps
Ya gotta pay attention and make sure the cord/plug don't get hot but ya also need to do that to the 30A stuff when you are really crankin on it...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 07-11-2010, 06:42 PM   #5
richinny's Avatar
2011 34' Classic
are you going to use an extension cord?
Ricky
Old 07-11-2010, 07:03 PM   #6
Barry
There is no "exact" current draw.
The sted current draw, is for a standard day ambient temperature.
However, the hotter the ambient temperature, the higher the currect drain.
As an example, on a "very hot" day, 105 to 110 degrees, that currect draw can get to almost 18 amps.
An extension cord is ok, but even for a short distance of 25 to 50 feet, the wire size should be about #6 awg.
Old 07-11-2010, 08:04 PM   #7
San Antonio , Texas
I am not sure if I will need an extension cord, but if I do, I have a 12 gauge 50' extension. It's interesting, but it seems that the line that feeds the unit in the roof is about 14 gauge. I might be close enough to use my 30 amp cord with an adapter. I always check the lines for heat, as well as using a analog voltmeter. I can't seem to locate the instructions for this the unit, but the Airstream manual states not to run it below 105 volts.
I will not be leaving the immediate area, and will be checking on the dogs periodically (every 15 minutes). Probably will just leave the windows open with the fantastic fan on.
At this point, I am just curious.
I also am not sure if it's the 13500 btu. The stream is a 2007 25' FB.
Barry
Old 07-11-2010, 08:06 PM   #8
lewster's Avatar
Naples, FL , Hood River, OR
The A/C might only pull 13.2 amps, but there are other electrical draws when plugged into shore power, like the converter, fridge on AC, etc.
The best way to determine if you are OK on a 15 or 20 amp circuit is to do an actual amp draw measurement with an AC amp clamp. IIRC, Sears has a little gizmo that plugs into the outlet and allows you to put an amp clamp around the hot leg, which is run thru it's own channel.
Or you could get a Kill-A Watt and plug it in. They are generally pretty accurate.
Old 07-11-2010, 08:31 PM   #9
richinny's Avatar
2011 34' Classic
it is a long thread but should answer many of the factors involved. ask again if you have more questions :-)
http://www.airforums.com/forums/f37/...age-51758.html
Ricky
Old 07-11-2010, 08:49 PM   #10
San Antonio , Texas
Excellent thread. Thanks. I will be using fans and hoping it is not too hot.
Barry
Old 07-11-2010, 09:31 PM   #11
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, Lewster. I was trying to test my system by running my Yamaha 2400 generator, Kill-A-Watt, and 11,000 BTU air conditioner. The Kill-A-Watt could not hold that large a load and was flashing. I disconnected it. My generator or 20 Amp house outlet runs my A/C just fine. I think the air conditioner and converter was too much for it. [Kill-A-Watt] Note: I think the Kill-A-Watt has some sort of built in safety, it was not damaged and I still use it in my trailer.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-11-2010, 10:03 PM   #12
San Antonio , Texas
On another note, which I am sure was discussed at an earlier time. Where would I be able to install one of those very quite & lightweigh Onans, or even the Honda generators? What about repositioning the batterys from behind the propane bottles.
Old 07-11-2010, 10:07 PM   #13
1975 29' Ambassador
Reno , Nevada
The confusion here is about what 15 amp circuit you are going to plug into. A standard 15 amp household circuit should have no problems with the RV A/C if that is the only thing on the circuit, the connections are good, and you aren't using extension cords.
Gensets sometimes have problems because they can't handle the compressor startup surge.
Standard RV power cords are 10 gauge for 30 amps at 30 feet. 6 gauge is only used for 50 amp RV service. See American Wire Gauge table and AWG Electrical Current Load Limits to figure out voltage drops. A 50' 12g extension will loose a bit under 3 volts at 15 amps. This will be OK if the supply voltage is above 115v. (if the circuit had 14g wire typical for 15 amp household circuits and you were 100' from the breaker panel, you'd loose near 8 volts. That'd be OK if the panel supply was 120v or better) -- the lesson is that the talk about wire gauge and so on isn't worth much unless the supply voltage is suffering and then the problem is really with the supply. A/C voltmeters can be found for $20 or so and are a good way to keep track of whether you are getting a proper supply to your RV (always more than 110v).
An autoformer will help assure against voltage drops but I am not so sure it'd be a good idea on a 'just fit' circuit such as this case. They can also provide protections from brownouts and some other problems so maybe.
A problem besides potential power faults is the fact that an RV does not have much thermal mass and an A/C can typically only provide 20 degrees of cooling. This puts time constraints on how long you can leave the dogs safely without checking. See how long by cooling the A/C on a hot afternoon and seeing how long it takes to warm in the sun.
Of course, you will want to have water available, sun protection (foil bubble foil insulation in the windows can help a lot), and perhaps a 12v fan to help circulate air. An RV is better insulated than a car and dogs can deal with warm if they have a cool spot to get to and water available.
Also keep in mind that there are those who see an animal in a vehicle, assume the worst, and call animal control to break in and save the animals from the heat. You might post a cell phone number on the door to call you if there are any concerns about the animals, maybe.
The Kill-a-Watt is a great way to check voltage and power draw (only $25, too). My guess is that it had problems with the initial surge or the power factor of the A/C. You could still use it to see the voltage inside with the A/C running.
Old 07-11-2010, 10:11 PM   #14
San Antonio , Texas
A/C questions.
What Amps??? Sundance Electrical - Systems, Generators, Batteries & Solar 8 03-31-2015 09:32 AM
AMPS 20? 30? 50? Which One Do I Want? Frank&Mike Batteries, Univolts, Converters & Inverters 7 06-24-2009 07:35 PM
How many Amps??? Sundance Batteries, Univolts, Converters & Inverters 3 07-02-2007 11:32 PM
Power required to run A/C Ken J Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-29-2003 10:02 AM
