Old 05-29-2011, 08:40 AM   #1
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
'Alternative' A/C - Will this work?
I have a 1960 18' Traveler which originally did not come with a roof a/c. Since I am trying to keep it as original as possible, I was trying to figure out a way to air condition it without putting in a roof air and, heaven forbid, a unit sticking out the window.
What I've come up with is this: Get a small window unit and install it in one of 3 places - under the bed (taking out a storage drawer), under the dinette bench or in the cabinet where the fridge is.
My plan was to construct a metal drip pan to go under the unit (with a drain hose) and a metal "air" box to go over it then vent the hot air and drip through a hole in the floor. I would have to cut a hole if I put it under the bed or bench but the fridge cabinet is already vented (it is the original propane fridge) through the roof and another screened hole in the floor.
Will this plan work? Would the back of the a/c be getting enough air circulation? Am I just asking for trouble cutting another hole in the floor? Or should I just find a small roof unit and run wiring to the ceiling vent? I only have 20 amps but could run a dedicated wire for the a/c.
lucymcdog is offline   Reply With Quote
Old 05-29-2011, 08:48 AM   #2
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Your problem is heat from the unit rises and has no where to go
Darkspeed is offline   Reply With Quote
Old 05-29-2011, 08:50 AM   #3
Darkspeed's Avatar
1972 31' Sovereign
The make a free standing portable a/c unit the exhausts it heat through a hose. Just stand it somewhere and run the hose to the outside
Old 05-29-2011, 08:51 AM   #4
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
I was thinking that the box that would go over the unit and vent through the floor would contain the heat and make it go out.
Yes or no?
I'm open to any and all suggestions.
Old 05-29-2011, 08:52 AM   #5
Darkspeed's Avatar
1972 31' Sovereign
De'Longhi 13000 BTU Portable Room Air Conditioner
Item #: 211844 | Model #:PAC A130HPEL
Old 05-29-2011, 08:54 AM   #6
Darkspeed's Avatar
1972 31' Sovereign
If you did it your way, and I'm saying it is not a good idea, you would need a blower to remove the trapped heat from the box.
Old 05-29-2011, 08:57 AM   #7
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
There was a post a long time ago about someone who mounted an AC to exhaust through a outside compartment space.
Old 05-29-2011, 09:02 AM   #8
Darkspeed's Avatar
1972 31' Sovereign
The thing that scars me about the idea is the possible proximity to the exhaust of any other gas system when your fresh air divider ( intake) is at the bottom of the trailer. Would you suck in any exhaust gas from any propane device at that location?
Old 05-29-2011, 09:12 AM   #9
pbearsailor's Avatar
Port Hadlock , Washington
Read Uwe's thread as he did it several years ago and AFAIK is still pretty happy with it. It's a very long thread, but lots of good info in it.
-steve
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 05-29-2011, 09:14 AM   #10
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
I could probably use the portable one under the table or maybe in the bathroom (we don't have much spare space in the trailer) and somehow figure out how to vent the hose. Do I need 13000 BTU or would 8,000 BTU be big enough? The interior is about 16' x 7' with most of that space taken up with bed, dinette and cabinets.
Old 05-29-2011, 09:20 AM   #11
Darkspeed's Avatar
1972 31' Sovereign
That is really up to you. They won't cool as much as they say on the box - I have one-
I posted lowes because if it is too big or too small you can return it or swap it without a lot of hassle
They are slightly louder than a window unit but it makes for some good sleeping
All you need to do is find a path for the 5" hose to exit your trailer
Old 05-29-2011, 09:22 AM   #12
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
I'd want to go with the portable room AC.
Path of least resistance.
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 05-29-2011, 09:26 AM   #13
Darkspeed's Avatar
1972 31' Sovereign
When you first plug it in give it half a day before you judge it .
It will have to remove all the accumulated moisture in your trailer before it will fell super cool
Old 05-29-2011, 02:19 PM   #14
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
-steve
Thanks for the thread - I've been checking it out and that split system looks perfect - although it IS a bit pricey. Now I've got to decide what to do...
Thinking of going Dual A/C Mr & Mrs S Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-04-2011 05:48 AM
Buyer Beware, Bad A/C installation barender Furnaces, Heaters, Fireplaces & Air Conditioning 6 05-23-2011 10:55 AM
Cleaning becomes a little work becomes a lot of work - 1964 GlobeTrottin 1960 - 1964 Globetrotter 6 04-30-2011 10:36 AM
A/C Replacement malopezmo Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-12-2011 02:34 PM
