Old 05-29-2011, 02:31 PM   #15
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Originally Posted by lucymcdog View Post
Do I need 13000 BTU or would 8,000 BTU be big enough?
In my 25' Tradewind I put in a 13,000 roof unit. I wish I went to 15,000. A consideration for you might be the amperage the units draw and what kind of camping you do. If you use a mid size generator you might have problems powering a 13,000 unit.
Old 05-29-2011, 04:21 PM   #16
toastie's Avatar
1955 22' Safari
Great Lake State , .
This is how I did mine, the hot air exhaust go out behind the license plate, works perfectly.
http://www.airforums.com/forums/f36/...-38289-38.html
http://www.airforums.com/forums/f36/...-38289-36.html
http://www.airforums.com/forums/f36/...-38289-54.html
toastie
toastie is offline   Reply With Quote
Old 05-29-2011, 04:56 PM   #17
rideair's Avatar
Go with a temp window unit
I would suggest a temp window unit. Here's a link to how I built a system that will keep your trailer cool, won't break the bank and can be installed in less than 15 minutes.
http://www.airforums.com/forums/f427...t-41052-2.html
Forgot to add "one" 6K unit keeps my 1966 22' Safari cool no problem
Paul Waddell
rideair is offline   Reply With Quote
Old 05-29-2011, 05:59 PM   #18
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Exhaust fumes not a problem
Air conditioners don't draw air from the outside on the cold side of the unit. They recirculate the air in the trailer. There are 2 heat exchangers (an evaporator and a condenser), one on the cold side for the inside air and one on the hot side for dissipating the heat. The hot side draws air from the outside, pushes or pulls it across the heat exchanger and returns it to the outside. Your referigerator works the same way in your house or trailer for that matter.
It is more efficient if the A/C unit is mounted higher up to draw in the hot air at the ceiling level or at least it should draw air from higher up.
Old 05-29-2011, 06:54 PM   #19
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Window units do.. and that is what was being proposed
There is a fresh air divider on most window units that allow for the addition of fresh outside air into the cold discharge
Darkspeed is offline   Reply With Quote
Old 06-04-2011, 07:42 AM   #20
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
Originally Posted by toastie View Post
I've been out of pocket with grandma duties lately but finally got a chance to look at your thread. Did you box in a portable unit and vent it through the floor? Or there was mention of a "casement" unit - not sure what that is.
The only time we need an a/c is when we're camping in the South - which isn't very often. I need the cheapest and easiest solution since most of the time we'll be in cool weather.
lucymcdog is offline   Reply With Quote
Old 06-04-2011, 09:24 AM   #21
Lumatic's Avatar
1993 34' Excella
Images: 16
There are freestanding, portable swamp cooler type room coolers. In the southwest roof mounted swamp coolers are the rule over AC. They work well in dry heat, not humid conditions.
Old 06-04-2011, 12:52 PM   #22
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
There are some other options like the Dometic Cool Cat Duo Therm or
Danhard Inc Mobile HVAC components and systems
Old 06-24-2011, 03:10 PM   #23
cutterbug's Avatar
2004 19' Bambi
afton , Virginia
So....what I am gathering here...is....yes a very small window ac would cool a small 13 ft space? If a insulated a cabinet space and did a floor drain tube/pan??? There is no danger in enclosing? If we heat with a teeny tiny ceramic heater...why wouldn't this work? I am thinking of doing the same thing for a little fiberglass vintage camper. I do not want to cut a hole in the fiberglass. There is plenty of space around the perimeter of the little egg on the floor. Forgive me....I haven't gone to all the posted links. Just in a little bit of a hurry. DEFINITELY do not want something hanging out of a window.
cutterbug is offline   Reply With Quote
Old 06-24-2011, 03:31 PM   #24
VIKING's Avatar
Boulder Creek , California
They only have to hang out when in use. Not near as bad as it sounds.
How about paying only $200 for your new window AC with remote control?
Or $50 for a used one on CL?
I mounted mine on a slide-out shelf in the location where my furnace used to live. The furnace cover is mounted onto the shelf, so it looks original from the outside.
Best to you!
Rich the Viking
VIKING is offline   Reply With Quote
Old 06-24-2011, 04:40 PM   #25
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I was in Wal Mart yesterday. They have an 8000 btu portable unit for $200.00 . I would think 8K btu would be enough for a small trailer.
Thinking of going Dual A/C Mr & Mrs S Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-04-2011 05:48 AM
Buyer Beware, Bad A/C installation barender Furnaces, Heaters, Fireplaces & Air Conditioning 6 05-23-2011 10:55 AM
Cleaning becomes a little work becomes a lot of work - 1964 GlobeTrottin 1960 - 1964 Globetrotter 6 04-30-2011 10:36 AM
A/C Replacement malopezmo Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-12-2011 02:34 PM
