Old 10-23-2013, 07:43 AM   #15
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Originally Posted by dwightdi View Post
The best way to winterize an Airstream is hook it to a TV and move 1,000 miles to the south.
That would put me just south of Key West, so I would have to stop a little short of 1,000. But, I could not agree more with your theory!
Alan
Old 10-23-2013, 05:59 PM   #16
Ottawa , ON
Personally, I don't understand why you feel a need to make it so complex. I would just set the thermostat to come on at 55 degrees during the time you aren't there, and whatever you like when you are there.
The gas system will make sure nothing freezes, day or night. Check that issue 'done' and go on to the next.
Oh, and the fan noise? You get used to it surprisingly quickly. Yes, really.
Old 10-23-2013, 06:14 PM   #17
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
Done! Moving on.
2013 Ram Power Wagon 2500 4X4 5.7 Hemi
2001 Airstream '34 Limited
Hensley Arrow
Fulltime in 2013 and LOVING it !!
truxpin is offline   Reply With Quote
Old 10-23-2013, 06:25 PM   #18
pgr32e's Avatar
1974 27' Overlander
Sault ste Marie , Ontario
One small note about running the fan without flame from the burner, you are then sucking cold outside air over the heat exchanger in the combustion chamber and cooling the cabin air in the heat exchanger. So the air you heat with the electric heater is being cooled going through the furnace......Phil.
pgr32e is offline   Reply With Quote
Old 10-23-2013, 06:32 PM   #19
Central , Mississippi
I have done exactly what you are asking. If the inside of the camper is 70 degrees and the fan is running...it's sucking in 70 degree air from inside the camper and swirling it thru the unlit furnace and out to the tanks. VOLIA! 70 degree air to the tanks with out burning propane...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 10-23-2013, 08:10 PM   #20
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Exactly.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
