1966 28' Ambassador
white hills
Air conditioning noise
A/C noise is not a ducting problem.
It is caused by taking an ac unit that is to small and run it at aircraft propeller speeds trying to get proper cooling.
Think about it / build the A/C unit a little larger, slow the fan down, problem solved.
Ducted A/C does not work well in extreme heat areas, sun overheats the roof and kills the A/C.
I have been told that the Dometic AC unit that Airstream currently uses for its new models is one of the noisier units on the market. I am nowhere near needing a replacement (I hope!) but if/when I do, I will look into this claim more thoroughly.
