Old 07-25-2009, 10:38 PM   #1
yakman's Avatar
2007 25' International CCD FB
Gahanna , Ohio
Air conditioning. Delay in coming on after setting thermostat..
Hello,
How long does your AC take to come on after setting thermostat to desired temperature?
I've set mine and it can take many minutes before the system will actually come on. It is being set to a temperature that is colder than the room temperature. Is this normal? Any thermostat driven AC that I've used will come on immediately. So mine seems to be suspect.
thanks,
yakman
yakman is offline   Reply With Quote
Old 07-25-2009, 10:47 PM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Originally Posted by yakman View Post
Hello,
thanks,
yakman
yakman,
In my trailer it may take two minutes or more before the fan starts and the compressor kicks in. This is on purpose. It is to protect the compressor from power outages. If the power comes on, then off, then on, etc. The compressor will not like it and likely die an early death.
Slightly off subject... This is my 3000th post! I am now a member of the get a life club!
Michelle TAC MT-0
Sarah, Snowball
Old 07-25-2009, 10:48 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have a 2005 25FB. We have spent 425 nights in her and have pulled her 50,000 miles. We have found the same thing. The AC takes 3 or 4 minutes to kick on after we have hooked into shore power and set the thermostat.
Brian
SuEllyn & Brian McCabe
Old 07-25-2009, 10:52 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Our AC also takes about 2 minutes to kick in as well...this is normal, as Michelle points out.
And congratulations on 3000 posts, Michelle!
TB & Greg and Abbey Schnauzer
AirForums #21900 . Membership Chair, 4C
Unit #3954
Old 07-26-2009, 01:25 AM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Our new Penguin does the same thing. The fan comes on, but it takes at least 3 minutes before the compressor kicks on.
Michelle, I'll see if I can find the award I received from the "Get A Life Foundation" when I hit 3,000, and send it to you...
Air Conditioning Question floridalarry Member Introductions 8 05-29-2011 01:10 PM
Air Conditioning, should it stay? HansenClan Furnaces, Heaters, Fireplaces & Air Conditioning 4 05-20-2009 12:25 AM
Air conditioning options jlester Furnaces, Heaters, Fireplaces & Air Conditioning 7 09-15-2007 11:25 PM
Air Conditioning help Chipster Furnaces, Heaters, Fireplaces & Air Conditioning 17 08-29-2007 08:16 AM
Air Conditioning Help Please!!! 85MH325 Furnaces, Heaters, Fireplaces & Air Conditioning 26 08-16-2003 09:58 AM
