Old 06-25-2008, 09:42 PM   #1
DrPlay's Avatar
2006 25' International CCD
Freehold , New Jersey
Air Conditioning at local campground
Heading down the street (2 miles) for a weekend of camping (gotta get out of the house). Turkey Swamp Park in Freehold NJ has tremendously large sites (100' x 75' or larger!) but each site has just 20 amp service. Will this power my AC (25' CCD International).
Brian
DrPlay is offline   Reply With Quote
Old 06-25-2008, 10:04 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
20 amp power is not really sufficient to run a 13,500 btu rv ac unit. It can give your ac unit problems on start up. I understand that this can sometimes result in damage to you ac unit.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 06-25-2008, 10:07 PM   #3
tpi
Trabuco Canyon , California
Should be fine. You probably cannot run microwave oven at the same time as the AC. It is possible (but unlikely) you'll have to switch your refrigerator to gas. If the batteries are in a very discharged state, you may have to allow them to charge for a half hour to an hour before switching on the AC.
I've used my AC quite a few times on 20 amp circuits.
Be sure to monitor voltage (as on any circuit).
tpi is offline   Reply With Quote
Old 06-26-2008, 06:38 AM   #4
willyd's Avatar
1993 34' Limited
Melbourne Florida , Springfield Ohio
The other problem could be power drops / surges which COULD damage various componets in your Airstream. Power drops / surges certainly are possible when a number of campers are using - especially 20 amp which is not recommended.
willyd is offline   Reply With Quote
Old 06-26-2008, 07:17 AM   #5
mandolindave's Avatar
It is going to be hot in N.J. this weekend...............
If you decide to use your AC leave the thermostat on full tilt cold. That will minimize the on-off cycles. The start up is where the damage can occur. I would also periodically check the voltage at the source and check your power cable for heat build up. Dave
mandolindave is offline   Reply With Quote
Old 06-26-2008, 08:01 AM   #6
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
Should be no problem if you your elect. useage to the A?C
jkcru is offline   Reply With Quote
Old 06-26-2008, 08:04 AM   #7
starflyte1's Avatar
2007 25' Safari FB SE
Lady Lake , Florida
You might want to use a voltage meter to check the power. As many on this forum know, we burned (?) out the capasitor (?) on our ac due to low power in campgrounds.
I bought a good quality voltage meter because I read somewhere that the readings of some the meters can be off as much as 10%. IIRC we try to have 106 volts.
If your ac is struggling (?) turn it off. Don't use a microwave or hair dryer at the same time with the ac.
If my husband reads this, he will have a fit because I know just enough to show how much I don't know. I do know that a good power source is necessary though.
We had 30amps added at home for the AS.
Sorry for the confusing post, but hope it helps a little.
Pat
AIR# 16756
WBCCI# 6167
starflyte1 is offline   Reply With Quote
Old 06-26-2008, 08:17 AM   #8
ME4US
me4us's Avatar
2007 27' Classic FB
Bath , Maine
Have fun in Freehold. Just move to Maine from Red Bank last year.
me4us is offline   Reply With Quote
Old 06-26-2008, 07:25 PM   #9
DrPlay's Avatar
Thanks everyone
Thanks for all the help. Won't have time to get a voltage meter AND wouldn't know how to use it anyway. Will bring several fans plus the two fantastics and hope for the best.
Oh!!!
Can I supplement power with my Honda 2000 (haven't used it yet). By itself I know it is not adequate for the AC, but if hooked up to the 20 amp park service plus the generator would that help??
Hey Red Bank -- coming to Maine this summer (5th trip) we'll be in Acadia then down to CapeCod in mid July. I'm jealous, Maine is my favorite East Coast destination.
Brian
Old 06-26-2008, 08:33 PM   #10
tpi
Unfortunately you cannot supplement the power with your Honda 2000.
This gauge plugs into an unused outlet and is about $10. at Camping World. If its in the green or a smidge below with the AC on you're OK.
The amp rating of the circuit and the quality of the power are two independent criteria. 20 amps refers to the break point of the circuit breaker. It does not imply low voltage or damaging drops in voltage. If the meter shows it to be OK, it is OK.
Old 06-26-2008, 08:47 PM   #11
moosetags's Avatar
You can unplug the refer in the outside box and plug it into the 2000si. That will probably do the trick.
Brian
Old 06-26-2008, 08:55 PM   #12
Ham KI4HJX
1982 27' Excella
1970 23' Safari
Franklin , 28734
Your Air conditioner only calls for a 20 amp breaker. Once it is running it will most likely pull only around 10 or so amps. My 81 Excella has a switch that only allows the air or microwave to run one at a time. If you run your Frige on gas you will be fine.
Ramp is offline   Reply With Quote
Old 06-26-2008, 09:19 PM   #13
DrPlay's Avatar
Thanks r AMP and Moose. While there is a Camping World about 15 miles away my guess is I can pick one up at Sears.
BB
Old 06-26-2008, 09:22 PM   #14
DrPlay's Avatar
Sorry thanks TPI.
Air Conditioning Question floridalarry Member Introductions 8 05-29-2011 12:10 PM
Air conditioning options jlester Furnaces, Heaters, Fireplaces & Air Conditioning 7 09-15-2007 10:25 PM
Air Conditioning help Chipster Furnaces, Heaters, Fireplaces & Air Conditioning 17 08-29-2007 07:16 AM
New AS Air Conditioning - Does It Work? DreamStream Furnaces, Heaters, Fireplaces & Air Conditioning 14 02-27-2004 07:01 PM
Air Conditioning Help Please!!! 85MH325 Furnaces, Heaters, Fireplaces & Air Conditioning 26 08-16-2003 08:58 AM
