Old 08-01-2015, 03:17 PM   #1
2004 30' Classic
tacoma , Washington
air conditioning
Can read thermostat no fan,can change modes, no air. Any suggestion
KLuce is offline   Reply With Quote
Old 08-01-2015, 04:20 PM   #2
bwpaint's Avatar
2015 25' FB International
my , house
Can you get the furnace to turn on? Not much info but could be no 110. That is what my thermostat does if not plugged into shore power. Maybe the breaker?
bwpaint is offline   Reply With Quote
Old 08-01-2015, 04:21 PM   #3
2004 30' Classic
tacoma , Washington
Thanks, will try.
Old 08-01-2015, 05:10 PM   #4
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
Check the breaker in the cabinet above the bed. When you run the AC, leave that cabinet door open. Make sure the filters are cleaned regularly, soap and water. I have an extra set as well. 110 won't run the Ac and it will need a 30 amp plug or the breaker will continually go off.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 08-01-2015, 10:29 PM   #5
2004 30' Classic
tacoma , Washington
Excellent. Switch blown , fixed.
New AS Air Conditioning - Does It Work? DreamStream Furnaces, Heaters, Fireplaces & Air Conditioning 14 02-27-2004 07:01 PM
air conditioning cowling and vent disintegration Rickj Furnaces, Heaters, Fireplaces & Air Conditioning 7 12-30-2003 01:04 PM
Air Conditioning Help Please!!! 85MH325 Furnaces, Heaters, Fireplaces & Air Conditioning 26 08-16-2003 08:58 AM
Air Conditioning Leak ccphoto Furnaces, Heaters, Fireplaces & Air Conditioning 5 06-15-2003 09:18 PM
Fantastic Fan or Air Conditioning??? Charcigar Roof Vents, Skylights & Fans 15 01-21-2003 08:19 PM
