Old 08-02-2012, 01:16 PM   #1
1977 27' Overlander
Cumming , Georgia
Air Conditioners, Where is the best pricing?
Hi guys, Asking here has paid off int the past so I figured I try here again
I have a 1977 27ft overlander, and I need to replace the A/C unit. I'm wanting to step up to a 15000 BTU unit and add heat strips. My LP furnace is brand new, but I thought it'd be cheaper to have the heat strips because i like my sleeping quarters to be cool.
Anyway, my questions is this. Where is the best place to get the best price on an A/C unit?
I was told to check out Palamnio Rv for my furnace and they were awesome and had the best price around. but their AC prices seem to be about the same as everyone elses. Any pointers?
Rofkrynn is offline   Reply With Quote
Old 08-02-2012, 02:06 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I wonder if they go on sale when the weather is cooler, like residential AC systems.
— David
Old 08-02-2012, 02:09 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Be careful with the selection of heat strips. We put in a smaller AC and the heat strip with it just smells warm. We run a Walmart portable electric heater instead because it is quieter and makes more heat.
Old 08-02-2012, 02:11 PM   #4
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
I put a heat strip in my 15,000 dometic, works ok but not great. We live in fl so we only need it at night. It was not really enough when it dipped down into the 40s.. Good for taking the chill out of the morning air. Keep in mind it draws a lot of amps. 12 amps if I remember correctly.
Silverflames is offline   Reply With Quote
Old 08-02-2012, 03:21 PM   #5
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
i like the idea of having the alternate option for heating. When you're at a campground, and the cost of electric is included, why not use the electric heat?
alternatively, at home, I'd want more 'bang' for my buck.... ie, a furnace.
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Old 08-02-2012, 06:34 PM   #6
1969 29' Ambassador
If I remember correctly Colin from the VAP talked about using one of the oil filled electric radiator. I would check the amp draw, but my guess it's about same as the heat strip.
Old 08-02-2012, 07:47 PM   #7
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I found the best price (at the moment) at AmericanRVCompany.com I went with a Penguin II 15K unit with a heat pump and even with shipping they were the most cost effective.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 08-02-2012, 07:49 PM   #8
Beneath the title
jnerges's Avatar
2005 28' International CCD
Mount Pleasant , South Carolina
The description of it smelling warm was awesome. Great blankets and occasionally an electric blanket if not boon docking. +1 on the oil filled radiator. The do great work.
Steer clear of kerosene heaters in the AS, makes for a messy clean up.
I have also been thinking about replacing our unit, its only 7 years old but it looks tired and sounds like an espresso grinding machine in Starbucks on a Saturday morning. (Loud)
Be interested if anybody has a solution or a place to purchase new.
Aunt Gladys, 28FT, Intl'
"Man, it's hot here, is the heat on?"
jnerges is offline   Reply With Quote
Old 11-04-2012, 08:43 PM   #9
cuyeda's Avatar
Long Beach , California
This is an old thread, and interested in knowing if anyone purchases the accessory drip pan for the Penquin II. Penquin II seems like a popular choice. I bought mine from American RV, close enough to pick it up from their warehouse saving a little shipping.
The owners manual does not mention the drip pan. Since I have the interior walls down, I was wondering about a drip pan, and if I should run the drain hose between the walls, minimizing a run off from the outside down the polished aluminum. My first AC install.
1947 Curtis Wright
1958 Traveler 18'
cuyeda is offline   Reply With Quote
Old 11-05-2012, 06:16 AM   #10
1969 29' Ambassador
From what I have read, water running down the side of side of a polished trailer leaves streaks. If you plan on polishing your trailer later down the road, it might be worth the investment.
Old 11-05-2012, 06:53 AM   #11
87MH's Avatar
1978 31' Sovereign
Images: 292
Been there - Bought it - Didn't use it
See this thread http://www.airforums.com/forums/f219...ign-14737.html , particularily post #85.
The Dometic "kit" really looked like a couple of clear plastic bra cups with some plastic piping attached...it may have worked but I opted on going with the full drip pan available from Airstream.
Would be interested in feedback from anyone on how the bra cups work.
The comment on roof runoff on polished aluminum is absolutely correct. Bear in mind that use of the heat pump on the Dometic Penguin II will cause condensate runoff from the roof mounted unit with ir without a drip kit..
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 11-05-2012, 07:26 PM   #12
cuyeda's Avatar
Will have to find comparisons to the footprint of both drip pans. I would think the specifically made pan for the Penquin would have a good footprint profile for the Penquin. As for the Airstream drip pan, is it a generic one size fits all, or is it made for specific model AC's? I am concerned of possibly finding an oversized pan. What do I know, haven't seen either of the pans.
Any comments?
1947 Curtis Wright
1958 Traveler 18'
Old 01-27-2013, 09:51 PM   #13
1978 Argosy 27
Lexington , Kentucky
I too am wanting to replace ours? Wanted to have the AC/heat combo as mentioned here but is it worth the extra $? Will most any model unit fit the roof of an Argosy?! Recommendations?
Jon
1978Argosy27 is offline   Reply With Quote
Old 01-27-2013, 09:53 PM   #14
1978 Argosy 27
AC/Heatpump Recommendations??
I too am wanting to replace ours? Wanted to have the AC/heat combo as mentioned here but is it worth the extra $? Will most any model unit fit the roof of an '78 Argosy27?! Recommendations?
Newby Jon
