Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 03-19-2002, 11:51 AM   #1
JAG
JAG's Avatar
Profile:
Air Conditioners
Who out there is using an A/C that is not an Duo-Therm Penguin? I am curious about the water rolling off the side as opposed to going through the drain in the trailer.I know that on the Penguins the drain comes out the left side of the pan looking to the front of the trailer. In my trailer, equipped with the original A/C it comes out the right, and does not go through the ceiling.
What are your thoughts on not using a Penguin. There is 200.00's difference in price for the same performance. Also I can get a heat pump for about 100.00's of savings. The only sacrifice would be the A/C draining off the trailer. If I used the trailer for a week and came home and washed the trailer, I wouldn't think I would have a big issue with staining??? Or will I??? Andy, would the "Walbernize" help this issue?? I am just trying to save some money...I am by no means a cheap skate, but at this point I am not real concerned with water draining off the sides, unless I need to be.
Please give me your honest opinions....
All will be greatly appreciated!!!
Thanks!!
Jimmy, Ashlee and Emma
1969 Overlander
1999 Ford F-250
JAG is offline   Reply With Quote
Old 03-19-2002, 01:01 PM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
I have had some experience with water draining from the A/C so let me give you my 2 cents worth.
I have had 2 Airstream trailers and now have a Motor home. My first trailer had a Coleman unit replacement. Water ran down the side.... Right over one of the windows. Not really an issue just an observation.
My second trailer still had the Armstrong unit, plumbed through the skin to drain on the ground. This was my first experience with the detail of thought that went into the Airstreams. Unfortunately the Armstrong died and we installed a Coleman with a heat strip. Again we had the water problem, but now it went over the vista views and a window and eventually down a curbside awning.
I personally think the drain is an elegant way to move the condensation from the roof to the ground without leaving any substance on the surface of your trailer.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 03-19-2002, 02:25 PM   #3
JAG
JAG's Avatar
Profile:
Thanks Joe...that would be great!!!....Although I am kind of leaning towards the Carrier AIR-V...I would like some info on what you find though!!
Thanks!!
1969 Overlander
1999 Ford F-250
Armstrong RV Air conditioners pap Furnaces, Heaters, Fireplaces & Air Conditioning 45 11-13-2006 09:35 PM
air bag air compressor dbyar Mechanics Corner - Engines, Transmission & More... 12 05-08-2004 01:58 PM
Removing Air Pump & Stuff swebster Mechanics Corner - Engines, Transmission & More... 6 03-10-2004 07:23 PM
Air Conditioner Question/Problem??? pscottn Furnaces, Heaters, Fireplaces & Air Conditioning 6 08-23-2003 11:21 AM
test
